Installed Stage 2 Comp Cams Yesterday
uploading more videos
you know what. when something goes wrong you can say i told you so. the dealer used zip ties on matt car also. im not worried about it.
i'm still holding out for the perfected tune and a dyno. great to see it running and sounding mean but until everythings working right it seems more show then go. thanks for guinea piggin for us and that goes to both you and matt.
I am sure with the stage 2 cams when he needs to adjust some things with the tuning, that his car will be running a hell of a lot quicker
Last edited by burzumaske20; Jul 16, 2008 at 03:19 PM. Reason: Automerged Doublepost
i don't doubt it'll be faster i just want to see by how much and where this newfound power lies. i'd rather not end up trying to wind out the engine like its a vtec, if you know what i mean.
Everything is working right. Also every car is going to act a little different; so you will never have a so called perfected tune. You have to adjust to what your ECU likes. Cams are an excellent way to make more power. The more air you can suck in and let out, the better. Trust me it has plenty of "go" to it. As far as "guinea piggin", It's not like we were experimenting to see if they would work. I knew for a long time I could put different cams in.
without upping the springs and retainers i'd call you a guinea pig my friend. whats up with some high revving load bearing vids?
Last edited by Spanky's Monkey; Jul 16, 2008 at 03:55 PM. Reason: Automerged Doublepost
You can accomplish the same thing by unscrewing the cam chain tensioner bolt from the back of the block. Why argue about this when it has been successful for 2 cobalts so far?
this is being debated now but they haven't gotten the revs that high yet due to the current tuning process. i believe whole-heartedly that these cams are going to build better power beyond the points that the stock springs are designed to manitain power at which point they will bind causing the valves to float.
