Installing a 2.0L supercharger on 2.2L
So heres the deal, I should have bought the 2.0L ss but when your 16 and horny for a car you make mistakes, so that was in 2006, recently I was at the junk yard looking at a cobalt ss and they have one with a mint motor, the back end was wrote off, I could really use some pointers and info on fitting a 2.0L supercharger, what mods will I have to do to get it on. Has anyone done this before, is it worth it? They want 850.00 for everything is this worth it, Let me know.
Thanks Mike.
Thanks Mike.
well it might be cheaper in the states this is canadian, now so far I know its the just the supercharger, i'm not sure about pulley's would they even fit, I find 850 a good price around here there around 2100 for a kit, so i'm thinking of going this way. I can get any parts I need off the SS to make it work, i'll check out the post, anyone got the link, and if 850 were to be expensive how much would you say ones worth, anyone buy one?
where did you get these parts, and i'm wondering right now with the US and canadian currency 1$ cnd is only worth 80 cents its costing me some money right now to buy parts lol but i just started and now i'm hooked, I just got my tenzo lowering springs anyone have these? with comments? and my twm short throw came in yesterday any comments on the short throw? and I have my audio with a dvd deck 4 kicker speakers 4 channel MTX 1 channel Mono block kenwood excelon amp. But anyways, Are those all the parts I would need to hook up a supercharger maybe they will included all this for 850 if I bring up some good points i'm sure i can get everything for 850 if anyone knows any good cnd web site for parts, hook me up i've look everywheres.
mine was $1,100, with all the parts you got and a pump/brackets, 42lb injectors, and a cobra HE. That was also 2 years ago before this was a popular mod to do and there was no demand for the parts
would you go for a kit for 850 if so what should i ask them inlcude so I dont look like idiot when I get there I would rather look like one on the site lol, but I appreciate all the support all ready, i'm part of a local forum, there not supportive and they make fun of me for driving a cobalt..
yeah i ran the stock SS injectors but i wouldnt recommend it for too long.
if you are oging to go with the stock injectors get the harness too.
Last edited by 07cobaltguy; Apr 23, 2009 at 12:54 AM. Reason: Automerged Doublepost
overthetopperformance.com or zzperformance.com
I thinkZZP is doing a promo now where the wiring harness comes free, but you'd have to modify it anyway to work with your engine
And tomorow when I go in is it possible just to get all the parts off the cobalt SS and bolt it onto my engine, obvioulsy not everything will fit but I would like to get as many parts as I can, Can anyone add more parts to this list, Thanks for the help guys.
SC
Intake mani
tensioner
idler
I/C pump bracket
alternator bracket
Full parts list for a 2.2 supercharger setup:
Supercharger
Supercharger Gasket
Stock LSJ Intake Manifold
LSJ throttle body
Intake Manifold Bottom Mount
Intake Manifold Gasket
LSJ Intercooler Pump
Intercooler Pump Wiring Pigtail or Butt Connecters
Heat Exchanger
Injectors
Injector Harness
Wideband
Boost/Vacuum Gauge
SS/SC gauge pillar
Stage 2 Belt
Extended Upper Radiator Hose
Coolant Reservoir Tank
SS/SC intake
LSJ Idler Pulley
LSJ Tensioner Pulley
Intercooler Pump Mounting Bracket
Heat Exchanger Brackets
Custom Idler Pulley with Mounting Bracket
NGK Copper Spark Plugs
20 gauge wiring
Zip Ties
Electrical Tape
Plastic Wiring Sleeves
Small and Large Hose clamps.
10ft. x ¾” I.D. Hose
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
two 8M bolt , with 1.25 threading and 120 mm length
one 8m bolt, with 1.25 threading an 130 mm length
coolant tank
Supercharger
Supercharger Gasket
LSJ throttle body
Heat Exchanger
Injectors
Injector Harness
Wideband
Boost/Vacuum Gauge
SS/SC gauge pillar
Stage 2 Belt
SS/SC intake
LSJ Idler Pulley
20 gauge wiring
Zip Ties
Electrical Tape
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
coolant tank
Supercharger
Supercharger Gasket
LSJ throttle body
Heat Exchanger
Injectors
Injector Harness
Wideband
Boost/Vacuum Gauge
SS/SC gauge pillar
Stage 2 Belt
SS/SC intake
LSJ Idler Pulley
20 gauge wiring
Zip Ties
Electrical Tape
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
coolant tank
Supercharger
Supercharger Gasket
LSJ throttle body
Heat Exchanger
Injectors
Injector Harness
Wideband
Boost/Vacuum Gauge
SS/SC gauge pillar
Stage 2 Belt
SS/SC intake
LSJ Idler Pulley
20 gauge wiring
Zip Ties
Electrical Tape
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
coolant tank
ThoR294
Oct 4, 2015 08:44 PM
