intake mani
Old Jul 8, 2009 | 12:18 AM
dayhoff35's Avatar
intake mani
ok i was told that if i upgrade to a 2.4 intake mani then i will see a decent gain in hp and i found this one on crateenginedepot is it the same http://www.crateenginedepot.com/stor...P1817C137.aspx
also does this just bolt on or how hard is the install
Old Jul 8, 2009 | 12:22 AM
HolyJerex212's Avatar
yeah thats the one they are talkin about...ive read its like a 13hp gain but you lose some low end torque...from what it looks like its an easy install
Old Jul 8, 2009 | 12:29 AM
dayhoff35's Avatar
ok thanks im trying to gain some more speed or acceleration so i can shutup my one friend he just keeps saying his old cougar would smoke my g5 he just says all i have to say is i have a 3.8 and you have a 2.2 when all my friends already told him my car is better so i want mine to smoke his so he will finally shut up
Old Jul 8, 2009 | 12:35 AM
http://www.crateenginedepot.com/stor...t-W67C144.aspx
thats actually the one you want.
Old Jul 8, 2009 | 12:36 AM
dayhoff35's Avatar
yeah thats the one i went to and when i click order here it takes me to the one i posted
Old Jul 8, 2009 | 10:42 AM
blackbolt89's Avatar
get it. you'll notice a little loss in low range torque but honestly if youre modding your car you're not going to be looking for power in the low rev considering anyone who gets on it is only going to be in low rev for 1st gear.
all in all it really wakes up teh car.
Old Jul 8, 2009 | 11:06 AM
1niceLS's Avatar
It's really not that difficult of an install on a 1 to 10 scale I would give it a 4.5 theres just a lot of disassembly to get to the old manifold. But all in all it is worth it, probably the best bang for the buck mod besides cams or N2O.
Old Jul 8, 2009 | 07:02 PM
jmz250's Avatar
One thing to consider, you're going to have to modify the brake booster hose a bit. It's located in a different spot on the 2.4 manifold, and you'll need a slightly longer hose. Not sure of the part number, but I believe if you go to a GM parts department and get a brake booster hose for a SS/NA, it should work.
Old Jul 8, 2009 | 08:18 PM
benjirman's Avatar
Or just go down to Autozone and pick up an 18" length of 15/32" hose, cost me all of 4 dollars. Put the break booster end on it and plug it in up by the drivers side firewall. But then take the other end and put it DIRECTLY over the vacuum nipple on the 2.4 mani, hose clamp it in place and move on. DO NOT try to use the old "QD" hose clamp thingy that held the vacuum line on the 2.2 mani, it will drive you insane, trust me I went that route first, spend the 95 cents on a hose clamp.
Took me maybe 45 minutes to do and it was my first one. Check out Maven's how-to in the how-to section, it walks you right through it perfectly.
and enjoy, it really does wake the car up.
Old Jul 8, 2009 | 08:24 PM
dayhoff35's Avatar
where did you guys order yors from?
Old Jul 8, 2009 | 08:29 PM
crateenginedepot...
Old Jul 8, 2009 | 09:16 PM
benjirman's Avatar
I ordered mine as 3 parts from gmpartsdirect.com
If you go that right you need the part numbers:
12587878: Intake Manifold, 1st design LE5 $125ish
12600729: Seal, Throttle Body $10ish
12589516: Seal, Crankcase vent $10ish
And those are the approx costs I paid. Took about 2 weeks for handling and shipping, but the savings was worth it! And this assumes you re-use the individual intake port gaskets, be careful with them and they are totally reusable if the engine is relatively new, mine had 65000 miles on it when I did mine and they were in pristine shape.
Old Jul 9, 2009 | 08:09 AM
ryansalazan's Avatar
So I've heard good thingsabout putting the 2.4 Manila on the 2.2. But two questions, the stock throttle body fits on it right? An lastly I'm going to buy a trifecta tune after, will this help it even more? Thanks guys
I've also noticed that it said for 05-07... I have an 08 and it said that the 08 had a different throttle body on it, anyone have an 08 and have done it? If so tell me how you liked it.
Last edited by ryansalazan; Jul 9, 2009 at 08:09 AM. Reason: Automerged Doublepost
Old Jul 9, 2009 | 03:15 PM
benjirman's Avatar
I believe Maven wrote the howto when he installed it on his 08 so should be fine. and yes the original TB migrates to the 2.4 mani, you move where one bolt is and it's a perfect fit.
I'm planning to finish my exhaust and possibly order up the 2.4 fuel injector rail and have a tune built for it and then put it on, i've read it goes into limp if you don't tune for it, but if I'm going to tune I just as well have EVERYTHING done before I pay the 300 bucks since I can't get it redone for free.
Old Jul 9, 2009 | 03:32 PM
1niceLS's Avatar
Not to thread jack or anything but I have question why are you gonna install the LE5 fuel rail??? Your stock one will give you all the fuel you could possibly want unless you plan on doing a big build like going FI or building the block up.
Old Jul 9, 2009 | 03:44 PM
benjirman's Avatar
also not to assist in the thread jacking, but yeah I'm planning to go turbo so it's just as well to do it now rather than later on the fuel rail.
Old Jul 9, 2009 | 03:52 PM
1niceLS's Avatar
Ok makes perfect sense to me now just at first I was like wait what? 2.4 fuel rail? for what? Good luck with the build
/endjack
Old Jul 10, 2009 | 03:55 PM
BLACK2007LS's Avatar
i wanna do this....ugh i wish i had more spending money
Old Jul 10, 2009 | 06:25 PM
warrenb213's Avatar
install is simple.
now that i've done it, i'm sure it can be done under 30 minutes no issues.
Old Jul 11, 2009 | 02:09 PM
really? anybody have any 08 instructions they would like to post cause i get mine tuesday
Old Jul 11, 2009 | 02:17 PM
warrenb213's Avatar
maven already has in the how-to section. specific to 08.
Old Jul 14, 2009 | 12:29 AM
dayhoff35's Avatar
one more ? about this if i get this and then decide to go supercharged there will be no problem with the 2.4 mani right?
Old Jul 14, 2009 | 09:11 AM
1niceLS's Avatar
To my understanding to go supercharged you will need the 2.0 LSJ intake manifold to go supercharged.
Old Jul 14, 2009 | 10:12 AM
Spanky's Monkey's Avatar
if you go turbo it won't be a bad investment, especially up top.......yeaaaaaaaaaaaaaaa!
Old Jul 14, 2009 | 12:00 PM
dayhoff35's Avatar
around how much more would the turbo be used do you think ive just been playing with the idea wether to go supercharged or not
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
