IonNinja Build
Old 10-20-2013, 07:00 PM
  #351
IonNinja's Avatar
Originally Posted by 574
Look at those cut hoses, no ***** given just kidding man. Nice picture of the valve springs, I may pick some up soon
I got frustrated pretty quick with those hoses. They were on there pretty good plus not in the greatest of locations so I said F it
There is enough slack in the hoses though to reconnect them. Worst case scenario I just pick up some new ones.
Old 10-21-2013, 07:09 AM
  #352
bmxracerchamp12's Avatar
its not hard to get them off lol. mine came off pretty easily after 112k miles and again over the weekend after 5k miles on the new block
Old 11-26-2013, 08:05 PM
  #353
IonNinja's Avatar
Finally got off my ass and took the old block off the stand and put my new block on there
Should be breaking the block down this week to put my new goodies in...
Old 12-14-2013, 01:43 AM
  #354
Quad-coupe07's Avatar
any farther man?
Old 12-19-2013, 06:26 AM
  #355
IonNinja's Avatar
I got a chance to work on the block again...
Removed the OEM pistons from the block
Then I took the bedplate off and removed the crank
Do I need any special sealant for the bedplate?
After that I started deglazing the cylinder walls
All four cylinders deglazed. Its kind of hard to see the details but do you guys think I hit the cylinders pretty good?
Next I plan to replace the crank bearings and bolts, re-install the crank and then I'll deal with the pistons and rods
Old 12-21-2013, 06:28 PM
  #356
looking great man! btw u get ur block worked on like decked or anything
Old 12-21-2013, 11:59 PM
  #357
IonNinja's Avatar
Nope
I just plan to check clearances and keep it movin. Not in the budget to bring it to a machine shop ATM
Old 12-22-2013, 09:30 AM
  #358
574
574's Avatar
I bought my zzp block used and it didn't need decked
Old 12-22-2013, 11:02 PM
  #359
noorj's Avatar
put a straight edge on it and check with a feeler gauge. the GM spec is 3 thousands flatness
Old 12-24-2013, 04:16 PM
  #360
2.2balt's Avatar
You have stock bore Wisecos? Which compression ratio as well? Planning on doing the same thing to mine (before the motor gives up lol)
Old 12-24-2013, 10:12 PM
  #361
1LowLS's Avatar
Yes and 10:1 ^^^
Old 12-26-2013, 12:28 AM
  #362
i have the same setup 10:1 and going turbo on it
Old 12-26-2013, 10:21 AM
  #363
2.2balt's Avatar
So its not really worth it to go with the overbored Wisecos? Planning on getting a second motor to build, but not sure if stock bore or overbore is better. I can't see the walls being so messed they'd have to be bored out beyond stock...
Old 12-26-2013, 08:19 PM
  #364
im sleeved .20 over. but you should not need to go bigger
Old 12-28-2013, 03:40 PM
  #365
06_ion2's Avatar
Are you finally going turbo'd now?
Old 12-30-2013, 05:22 AM
  #366
IonNinja's Avatar
So I was cleaning my pistons off and I found this on #3. Same cylinder that I spun the round bearing on
I dont remember any of my valves looking unordinary but now I'm all paranoid
Gotta scrap together some piston money now though regardless
Btw that's a shitload of carbon buildup for only ~3k miles!
Old 12-30-2013, 06:03 AM
  #367
1LowLS's Avatar
looks like from oil too.weird.could be the guides gave out and had enough slop to tap the piston.
Old 12-30-2013, 05:30 PM
  #368
IonNinja's Avatar
I think the contact happened when I disintegrated my rod bearing
I was definitely burning a shitload of oil though, all 4 pistons look like that
I must have been super tired when I posted this though because I forgot I had a different head on the car when this happened so my current valves should be fine.
Build is on pause until I get a new piston and I need new lower crankcase perimeter bolts. For some reason I didn't order them when I got the main girdle bolts.
Old 12-30-2013, 05:33 PM
  #369
IonNinja's Avatar
Unless your cylinder walls are fubar'd I would go stock bore. The sleeves are not that thick to begin with
I was hoping to go turbo next tax season but not looking likely now
I'll worry about that once I get this bish up and running
Old 12-30-2013, 05:35 PM
  #370
IonNinja's Avatar
dbl post
Old 12-31-2013, 12:08 AM
  #371
noorj's Avatar
you run a catch can?
Old 12-31-2013, 01:17 AM
  #372
IonNinja's Avatar
I wasn't...I have one now though
I think most of that build up is due to worn valve guides in my old head
Old 02-01-2014, 01:23 PM
  #373
got any updates man? I love this tread and am going to build my ion qc after taxes get here
Old 02-01-2014, 07:26 PM
  #374
IonNinja's Avatar
Nah, I still need more bolts and at least one new piston
I'm considering getting all new pistons though because I'm unsure of the condition of the piston skirts on my current ones
Old 02-02-2014, 10:47 AM
  #375
taking his sweet ass time lol. dont worry i havent touched mine in almost 6 months. slowly acquiring new parts and we have over 2' of snow
Quick Reply: IonNinja Build
