L61 Low Psi turbo w/ stock Fuel System?
Old 02-18-2007, 04:18 AM
jperris's Avatar
I was wondering if anyone has actually tried running an L61 with a turbo or s/c setup with the stock fuel system, starting with a very low boost pressure and gradually adding more to see at what point the stock fuel injection system fails to provide a correct mixture. I would think that, being an air mass system (as opposed to speed/density), you would be able to run at least a couple pounds of boost without any problems. Who knows, maybe you could get away with running 5 psi or so with nothing more than a rising-rate fuel pressure regulator. If anyone knows of any testing like this that has been done, I'd love to hear about it.
Old 02-18-2007, 07:27 AM
cyrix's Avatar
There is only one forced inductino kit out there at the moment for our 2.2L and thats the Alpine turbo kit. They've got it running 8 psi on stock everything.
https://www.cobaltss.net/forums/forced-induction-50/2-2-turbo-finished-44321/
Theres the link to the many page thread on what it all is.
http://www.alpine-developments.us/cobalt_dyno.htm
Info on this kit. Its not CARB certified but will pass emissions.
-edit-
I think I might of answered ur question wrong, if i misread please feel free to call me retarted
Old 02-18-2007, 08:57 AM
06_ion2's Avatar
actually the stock injectors will only flow for 5psi at max flow.. there using a 5th injector system that is powered and tuned by a piggyback smt-6 on there turbo applications.. the stock ss/sc injectors should fit and when a tune is released for the 2.2s just watch for the number of boosted L61s raise
Old 02-18-2007, 09:00 AM
ecotecon18s's Avatar
My buddy just turboed his base model cobalt 2.2 and said he cant get over 3psi before the car starts to act like crap...he's about to get it tuned here in the next week...
Old 02-18-2007, 09:54 AM
06_ion2's Avatar
he cant tune it unless hes going smt-6 or aem standalone or maybe a dmfu the 2.2 isnt cracked as of yet.. bet bet is to use the smt-6 with the 5th injector system..
Old 02-18-2007, 02:33 PM
jperris's Avatar
thanks, that's what i was looking for. anyone have any info on the stock L61 injectors (flow rates, manufacturer, part number, high/low impedance)?
Old 02-22-2007, 12:09 AM
LewiSS's Avatar
Two things need to be done under boost: increasing fuel and decreasing ignition timing. The stock computer doesn't read boost, so it cannot be programmed to perform these functions. HPTune can be used to make the system rich on high throttle openings, but it will be a compromise. And HPTune may be able to reduce timing on top end, but, again, it will be a compromise as it will occur whether boost is high or not.
The smt-6 reads boost through a sensor, and controls the pulse width of the extra injector according to amount of boost. So it actually performs fuel management incrementally as boost increases. It also modifies timing incrementally. This gives the best, safest control.
John at Alpine Developments has designed multiple factory turbo systems, including ones used by Toyota in the South African market. I trust his designs - they are virtually "factory equipment."
Turbo Johnny
02-21-2019 09:41 AM
vjoel2011
10-02-2015 12:11 PM
TylerJHowell
09-21-2015 06:47 PM
jcalvin1126
09-11-2015 10:24 AM
Josh@ottp
09-08-2015 10:18 AM
Quick Reply: L61 Low Psi turbo w/ stock Fuel System?
