Launching Question
Old Jun 25, 2007 | 11:32 PM
Bobbo's Avatar
Launching Question
I own a 06' Cobalt Lt that I've have had for about a year now and have done numerous mod's to it since then (header, exhaust, CAI, etc.) However, I decided to gun it on a nice open road not to long back and noticed that when I did the Traction Control kicked in and really pissed me off. I don't recall this happening when my car was stock and I am not aware of any ways to disable this. I've been researching it a little but haven't found a definite answer and was wondering if someone could help me out.
My second question is when I do decide to go WOT at anytime I feel a pull in my car and it gets much harder to turn, almost as if the car is very stiff. I am assuming it is from the sudden forward momentum and was wondering if there was a part I could install in my car to prevent this and make the car handle better when I do put the pedal to the floor?
Thanks for any input!!
Old Jun 25, 2007 | 11:37 PM
daman
Guest
Posts: n/a
Your expiriancing torque steer. I don't belive you can do anything about that.
If you have an auto you can put it in low and it will disable the traction control, or one notch on the E-break will do it also
Old Jun 25, 2007 | 11:57 PM
Bobbo's Avatar
Thanks for the input... By the way your rims look nice.
Old Jun 26, 2007 | 09:26 PM
daman
Guest
Posts: n/a
No problem! And thanks here's a couple more pics!
And I have SSC springs sitting right next to me. I just need to find time to put them on. Probably this weekend.
Old Jun 26, 2007 | 09:30 PM
YSUsteven's Avatar
Wider tires would help a little.
Thats just how front wheel drive cars are, there is no way around it.
Old Jun 26, 2007 | 09:35 PM
D4u2s0t's Avatar
is it an automatic? if so pull the e-brake one notch and it will turn it off.
Old Jun 26, 2007 | 09:39 PM
OrngBalt's Avatar
If you use the search Halfcent did a good write up on launching an automatic. Take a look at it.
I wonder if there is a way to trick the car into thinking the ebrake is enabled without pulling it. I suppose the only other way would be to pull the fuse on TC
Old Jun 26, 2007 | 10:24 PM
Bobbo's Avatar
The background in those pics really sets the car off...good **** daman
Old Jun 27, 2007 | 10:13 PM
daman
Guest
Posts: n/a
Thanks man!
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
