LNF is need of assistance from a 2.2 brother
hey all, as stated in the title, I have an LNF balt. but I need help from you guys. can one of you measure the diameter of your alternator pulley for me? Im getting 2.5" with mine, I want to see if yours is the same diameter.
thank you
08SSTC
thank you
08SSTC
both the lnf turbo and the 2.2 use the same belt routing and direction. the LNF uses a different alt as far as i can tell, different part#'s at least. just want to make sure the pulley is the same diameter
yeah its the same size the alt can only recharge one way on the ss/sc the 2.2 alt charges bolth ways. im spinning mine backwards on a smooth pulley.
according to acdelco and various online catalogs, the LNF uses a different alternator than the 2.2l fwiw. granted, im sure the alt pulley may be the same, but I am double checking.
while true supposedly the 2.2 and 2.4 used to use a different alternator as well the difference is the 2.4 one puts out like 5 more amps or something so it could be something like that.. I can't find my other damn alternator pulley right now sooo idk what the exact measurement is .. fail on me
