low oil pressure
low oil pressure
I have a 06 Chevy cobalt ls with the 2.2l ecotec I recently put a turbo on it was pushing 8 psi when I origanally turboed it it was pushing 80 psi oil pressure cold at idle I have had it turboed for about 3000 miles maybe a Lil more just city driveing not for long periods of time then I started it recently and only 40psi cold at idle start when I rev it it easyly gets past 60 psi but I don know I was planing on rebuilding it full internals but I don wanna have this issue after the rebuild any info to what u think is loosing my oil pressure I think I could have messed up my bearing cleareances but not sure anyone had this issue??
What oil? With hard use some crappy oil cold have had viscosity break down in the 3k miles with a turbo car. Viscosity breakdown would cause lower oil pressure. Change to oil and see if the pressure goes back to normal.
I changed the oil full mobile 1 synthetic and Lucas oil stabaliser changed the oil filter and changed the feed to come from the block hope that helps I have never had a low pressure light go on but the guage reading scared me
No ticking or knocking but it just started to rev when I started it so I killed it but Idk should I just say **** it and start my rebuild early? And tear it apart? And check my bearing cleareances
Sl0wbaltSS
Nov 21, 2018 11:11 PM
importkiller
Sep 30, 2015 07:18 PM
