LSJ Ex. Mani and DP
I'm pretty sure there's a problem with where the engine sits. They will bolt up but you will have to mess with the length a bit cause the auto sits more forward? do some search to get a more clear better answer
bump. need to know if this will fit
Last edited by HyperMuffin; May 10, 2010 at 08:42 PM. Reason: Automerged Doublepost
okay to clear this up...I have both, and ps file out that Exhaust mani for better flow, and it should will bolt up directly the only issue is the DP will rattle, so you have to adjust its length a bit, very simple for someone at a shop to do if you dont have the tools yourself.
hes not saying it will and im not saying it wont... i said it wont BOLT RIGHT UP.... it can be made to fit.... and hes not saying it will bolt right up, hes saying ADJUST THE LEGNTH.. as in cut it and weld it im guessing?
and btw it will bolt up just fine. just when the car is running and in gear while stopped it will rattle. i should know, i had it installed.
hypermuff the DP will NOT fit without knocking on the front sway bar.
So let me gwt this straight. The LSJ mani and dp will bt up but since i have an auto tranny and the dp is a bit shorter it will hit against the sway bar and make a rattling noise? If it can be installed and bolted in fine thats all i need. I could care less about the rattle when it id in gear, my exhaust rattles a bit now when in gear and stopped.
Blackbolt is right. I had that setup for a little while, now I am running the JBP Vortex header and a 3" CTI DP and it has the same issue. Mine only hits when it shifts though, it is fine at idol...
mine also rattled for a little bit prior to me raising it a bit, and it only rattled in D when stopped occasionally for me, so id just tosss it into neutral if it that, that usually gave the DP enough clearance
