LSJ Ex. Mani and DP
Old May 10, 2010 | 07:13 AM
HyperMuffin's Avatar
LSJ Ex. Mani and DP
2005 auto 2.2L. Will the LSJ exhaust mani and lsj dp bolt up since im an auto tranny?
Old May 10, 2010 | 05:41 PM
SmackinJuice's Avatar
I'm pretty sure there's a problem with where the engine sits. They will bolt up but you will have to mess with the length a bit cause the auto sits more forward? do some search to get a more clear better answer
Old May 10, 2010 | 08:42 PM
Thats what I figured. Anyone else want to chime in?
bump. need to know if this will fit
Last edited by HyperMuffin; May 10, 2010 at 08:42 PM. Reason: Automerged Doublepost
Old May 11, 2010 | 09:06 AM
rockstarbass1's Avatar
Auto tranny is a no go, won't bolt right up trans is in the way
Old May 11, 2010 | 01:34 PM
s h a y n e's Avatar
okay to clear this up...I have both, and ps file out that Exhaust mani for better flow, and it should will bolt up directly the only issue is the DP will rattle, so you have to adjust its length a bit, very simple for someone at a shop to do if you dont have the tools yourself.
Old May 11, 2010 | 03:30 PM
Alright so one person says it wont fit but one says it will. Will it cause any damage if it is rattling and how would I adjust the length?
Old May 11, 2010 | 05:14 PM
hes not saying it will and im not saying it wont... i said it wont BOLT RIGHT UP.... it can be made to fit.... and hes not saying it will bolt right up, hes saying ADJUST THE LEGNTH.. as in cut it and weld it im guessing?
Old May 11, 2010 | 05:19 PM
blackbolt89's Avatar
and btw it will bolt up just fine. just when the car is running and in gear while stopped it will rattle. i should know, i had it installed.
hypermuff the DP will NOT fit without knocking on the front sway bar.
Old May 11, 2010 | 05:55 PM
So let me gwt this straight. The LSJ mani and dp will bt up but since i have an auto tranny and the dp is a bit shorter it will hit against the sway bar and make a rattling noise? If it can be installed and bolted in fine thats all i need. I could care less about the rattle when it id in gear, my exhaust rattles a bit now when in gear and stopped.
Old May 11, 2010 | 08:09 PM
tru2nrtt777's Avatar
Blackbolt is right. I had that setup for a little while, now I am running the JBP Vortex header and a 3" CTI DP and it has the same issue. Mine only hits when it shifts though, it is fine at idol...
Old May 11, 2010 | 08:52 PM
mine also rattled for a little bit prior to me raising it a bit, and it only rattled in D when stopped occasionally for me, so id just tosss it into neutral if it that, that usually gave the DP enough clearance
Old May 11, 2010 | 08:57 PM
Alright awesome. I'm not to worried about the rattling, I'm just glad it will fit before I actually attempt to install them. Thanks for all your help!
Old May 11, 2010 | 10:01 PM
yeah thats what id have to do. but throwing it in neutral in stop and go traffic because people are giving you the face got kind of annoying after a while. lol
Old May 12, 2010 | 01:16 PM
yup hahah exactly
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
