Manifold differences
Old Mar 30, 2006 | 12:45 PM
redlineblueline's Avatar
Does any one know if there is a difference in layout of the 2.0 and 2.2 exhaust manifolds? The reason I ask is I bought a Pacesetter header before I found out I might be able to trade in my 2.2 for a 2.0 and I want to be able to keep it if its ot to different in the layout. Also if the layout is the same is anything else a problem with fitting? Thank you.
Old Mar 30, 2006 | 12:49 PM
Halfcent's Avatar
I'm old school
I don't the answer, but I know where to find it. Call Pacesetter.
Old Mar 30, 2006 | 12:51 PM
RedBaseBolt's Avatar
I would assume it would be different because of the displacement difference.
Don't quote me on that though.
Call Pacesetter like HalfCent said.
Old Mar 30, 2006 | 03:20 PM
Accorrding to Pacesetter: hello , the header will bolt to the motor , but the ports and primary tubing size are on the small side , for the amount of power the 2.0 s/c makes .
also the short extension was made to fit the 2.2 cat which is roughly a 2" inlet , and i believe the 2.0 s/c is a 2 1/2" inlet .
we are going to be working on a header for the 2.0 s/c , but at this time im not sure as to when they will be avaliable .
Eric Remboldt
Customer Service
602-266-1964
eremboldt@pacesetterexhaust.com
Are his numbers correct?
Old Apr 1, 2006 | 01:35 AM
NJHK's Avatar
Eric Remboldt
Customer Service
602-266-1964
HAHA
I knew you talked to Eric...Trust me, Eric knows his s**t. I talk to him frequently and is a avid JBO member. What he says is true.
Old Apr 3, 2006 | 04:04 PM
Roadrunner's Avatar
Originally Posted by NJHK
HAHA
way to know somebody
its his product, so i dont see why he would give you any bad measurements on it. despite pacesetters low quality on some of their stuff they do always seem to give what they promise.
Old Apr 3, 2006 | 05:44 PM
NJHK's Avatar
I agree that most of their stuff is low quality compared to others but as long as you get their header ceramic coated, you should be fine.
Old Apr 4, 2006 | 11:04 AM
Roadrunner's Avatar
i agree, thats what i have sitting under the hood of my cav. its been there a while and still looks pretty damn good, but a turbo would look better.
Old Apr 4, 2006 | 11:27 AM
NJHK's Avatar
oooo yeah
(sorry I'm biased lol)
Old Apr 4, 2006 | 08:53 PM
IonNinja's Avatar
Redline:
manifold opening of 15/8 by 11/2, ports are 11/2 wide by 1" tall, 3" collector
according to Jason Smith
1 1/2" ports and 3" collector
ours are similar in size but with a smaller collector I believe...not too much difference between the two.
Old Apr 9, 2006 | 02:08 PM
Anyone know the torque specs? And also for ***** and giggles does anyone know the part number for the manifold back stock exhaust?
Old Apr 14, 2006 | 03:19 AM
Can some one measure the length of pipe from the engine to the joint in the pipe between the resonator and the cat? Also BUMP on the ^^^^^^^^^^.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
