For the mechanics
For the mechanics
A 2.2 cobalt ls with a kand n typhoon kit, jet chip stage 2, weisco forged pustons, comp cams, 2.4 mani swap, magnaflow exhaust, headers, msd ignition, bosch +4 plugs ,i wanna see what the most hpi can get w/o forced induction no flaming im a newb
idealy my question really is whats the most i can get from my 2.2 before turning to forced induction. I read on pulstar spark plugs that just for those alone it will add 5 hp, but yes what the max i can get on the 2.2 and what does the trifecta tune do or add?
ok, you have a bit of the right idea but honestly look how much its going to cost you to do that. replace the jet chip with a real tune, the cams for a decent turbo like a EvoIII 16g, and a turbo exhaust manifold for the 2.4intake mani. you then just need to spend a little more on piping and injectors and you have yourself a 200+whp cobalt with potential vs maybe a 180whp cobalt that's close to maxed out.
its still a decent turbo and you really can't beat it for the price. it costs the same as the cams and brings a hell of a lot more power.
I'd LOVE to see proof of that...those plugs are nothing more than a gimmick. The only good thing that might come from them is that since the plug is only gonna use one electrode at a time (it doesnt spark to all the electrodes at once) they MIGHT last longer.
What I'm saying is, long-term, it is FAR FAR more expensive to build a NA four cylinder than a FI'd one.
if your absolutely intent on it....neutral balance shafts, new valves 1mm larger, port the head, new valve springs/retainers, this means new headgasket, new head studs, new cams (comp stage II probably), lightweight crank pulley, 2.4l manifold, a fatty intake, and a tune....your talking about $2,000 in the head, another $350 for the balance shafts, another $300 for the crank, $400 on the cams, $300 on the tune, $250 on the intake, and w/e the head studs/gasket cost. upwards of $3600+ and youll see a little over 200hp...
not to mention install on those is a bitch, they all involve getting inside the engine...thats a lotta $$ for a professional install
I would say just build you your engine a little bit and go turbo with tune.
If you wanna get technical, you can make your 2.2 500hp na, hell there's even a GM racing book that shows you exactly how, but like the other guy said, it's very expensive and not worth it.
its why i just bought an M62 and intake manifold...ill be at over 220hp for $1500 + $300 for the tune....thats cheaper than just the head on the hypothetical NA cobalt above...
the 2.4 manifold alone with a cai and exhaust nets 150hp at the wheels. with the tune you'll surpass that by a few horses. i figure a good setup should net 170hp+ to the wheels.
to put it in perspective i can spank my buddies 05 ser spec-v which on paper would mean i was putting out more at the crank then his 175hp.
