motor help
Old Jul 19, 2008 | 01:35 AM
madmark's Avatar
motor help
i got my block back from the machine shop and started putting the parts back together. i put the crankshaft bearings all in place and used some bearing grease to spin the crank. without the lower crank case the crank was spinging. so i put the case over it and tryed to spin it again and no luck....... i printed the torque specs of mitchel and it says 15ftpounds and the a degree turn (dont remember what degree this moment) so i pulled the lower case off and every thing looked alright..... tryed it again and it did the same thing. i got really frustrated and quit for the night
any ideas?
Old Jul 19, 2008 | 03:28 AM
silverfae7's Avatar
15lb/ft + 70* SI says to use clean engine oil to lube the bearings. Thats what I use when doing them under warrenty and have never had a problem. Maybe the grease is too thick. Did they have to redo the bearing surfaces? Make sure you have the right size bearings. Just throwing out some ideas.
Old Jul 20, 2008 | 02:45 AM
bridfi's Avatar
plastigage plastigage plastigage
never trust new bearings are perfectly right.
that crank should spin easily.
Solaris99
28
Mar 15, 2017 01:22 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
