Mrz Pulleys and belt squeaking problem
So i just put my new MRZ pulleys on and the new belt and i drove it around and the first day it was great no problems at all and now the last two day my belt has been squealing like hell and i looked at everything and it seems like the tensioner isn't holding tension on the belt so is there any way to adjust this or do i need a new one or what and if i do wher can i get one and a part # ?
You need to make sure that the pulleys are aligned properly, as little as 1.5mm misalignemtn can cause nasty noises and accelerated wear. if it was machined wrong theres nothing you can do.
I'm pretty sure they are all aligned properly. I know the problem has to be the tensioner because i can just reach in and spin the tensioner pulley without a problem cause its not tight against the belt
Oh ****, I missed the whole part about the tensioner, LOL
Its spring loaded, and you need a new one it its failed. If youre SURE you have the proper belt youll need a tensioner.
Noy a good idea...it may not be squealing but you can be sure there is a lot of slippage so your alternator may not be putting out much of a charge.
Tensioner PN out of the 07 Parts book for the 2.2 (and 2.4) is 24430296
patooyee
Oct 1, 2015 01:07 PM
