my alternator is making sounds
Old Dec 30, 2009 | 12:50 AM
jonxxxedge1's Avatar
a few weeks ago there was a sound coming from my serpentine belt area. it only happened for one day then went away. so i changed the serpentine belt just in case. the other night i was coming home and it made the sound again. then it stopped the next morning. could the bearings in the alternator be going?
Old Dec 30, 2009 | 01:03 AM
nhanson's Avatar
alternators make noises when they are about to stop working...just have one on hand when it needs changing...good luck too cause it looks as tho these cars are hard to change
the battery light should come on when there is low volts
Old Dec 30, 2009 | 10:53 AM
06_ion2's Avatar
No there easy to change. 3 bolts 20min tops. your battery light will come on at about 10.8v so if it does that make sure your headlights are off or you wont make it far without any spark.
Old Dec 30, 2009 | 11:01 AM
its not very hard to get too just take the wheel and wheel well off. is that covered under power train warranty?
Old Dec 30, 2009 | 11:17 AM
huckernage's Avatar
nope
Old May 19, 2011 | 09:08 PM
tanelk's Avatar
So the battery light will come on if the alternator is about to go?
Old May 19, 2011 | 09:26 PM
juice3's Avatar
yeah my battery light came on and off before mine went out. And if i remember correctly, it stayed on like 20 mins before it completely went out. Luckily it died as soon as i entered my neighborhood. I made it home but with all my lights out, and no power steering. Just loosen the belt, remove supercharger and you can change it easily.
Old May 20, 2011 | 11:42 AM
Phil424's Avatar
Why in the hell would you have to remove the supercharger? You can get at it through the wheel well like your suppose too.
Old May 20, 2011 | 06:12 PM
juice3's Avatar
I wasn't aware of that approach. That sounds good too. People were telling me to remove supercharger back when I was doing it.
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
jimbofug007
Oct 2, 2015 12:06 PM
Stuff
Oct 1, 2015 05:47 PM
