My cavalier is sick, I think.
Old 03-14-2008, 08:05 PM
Borderlin3's Avatar
So When I am accelerating, it doesnt sound like I am getting the full potential of the car, it sounds EXTREMELY bogged down, could relate it to a noise if something was being blocked, and the car vibrates a little, I can tell because the rear view mirror vibrates alot only when accelerating. My mom has a G5 and it has the same engine, and it sounds and feels a WHOLE lot different and powerful , so I know SOMETHING is wrong.
What could be causing it to be making this bogged down noise, like something is being restricted.
Ive checked the air filter and all is fine there.
Could a tuneup fix this problem?
Its an 04 5spd 2.2
Old 03-14-2008, 08:07 PM
XM15's Avatar
Its not throwing any codes? Maybe its a fuel filter or spark plugs.
Old 03-14-2008, 08:09 PM
HackAbuse's Avatar
First thing I'd do, change the plugs, and clean the MAF, then reset the PCM and see where that gets you
fballman1987's Avatar
fuel filter, fiel pump even, the same thing happened to my 03 cavi and the fuel pump died in the middle of traffic.
Old 03-14-2008, 08:25 PM
Dispute's Avatar
Does the exaust sound restricted, if so my first guess would be the cat. Let your car run for a while revving on it a few times and then look under your car to see if the cat is glowing red. If so its clogged.
Old 03-14-2008, 08:27 PM
Borderlin3's Avatar
I am gonna go out and check the cat, I just got this car monday and am COMPLETELY new to ecotecs, where is the fuel filter and maf sensor?
Old 03-14-2008, 08:55 PM
brandon2.2's Avatar
check the Throttle Body. How many miles does your car have? Those same symptoms could be related to a dirty throttle body.
The MAF sensor comes right after the air filter somewhere on the intake before the throttle body.
Old 03-16-2008, 09:38 PM
Section8cav's Avatar
need to get codes checked..just cus it isnt throwing a light doesnt mean a code isnt set...doubt its a fuel filter..injector is likely..but those things will usually cause a miss...and a clogged cat will set an 02 code( when it gets THAT bad )
Old 03-16-2008, 09:39 PM
boostedss26's Avatar
auto or manual torque converter lock up? nvm i see its manual
ricklovin93
08-27-2016 06:35 PM
Delta coupe
09-30-2015 08:11 AM
dasoftest
09-29-2015 02:14 PM
GM_Mike
09-19-2015 02:43 PM
Highgross89
20
09-11-2015 03:24 PM
Quick Reply: My cavalier is sick, I think.
