Need exact proceedure in removing SAI
Old 12-30-2008, 03:23 PM
D4u2s0t's Avatar
Originally Posted by OrngBalt
Now where would you POSSIBLY get an idea like that?
just a hunch
Old 12-30-2008, 05:50 PM
Maven's Avatar
Originally Posted by D4u2s0t
just a hunch
Mine will be going nowhere, I am gonna leave the entire system as intact as possible. keep it stealth, plus I like the sound it makes(and I cant be bothered to remove, many more important things to waste my time on)
Old 12-30-2008, 06:20 PM
Raiden8816's Avatar
if i'm thinking about the same one you have to wiggle your fuse box and take off the headlight to get it out it's a bitch
No thats a rubber hose next to the fuse box. This is is behind the block, and I believe it "used" to go to my pump. I also have four bolts, again that "used" to go to the pump. We but all the bolts back into the block and the longer one for that metal hose behind the right rear of the block that does absolutely nothing now lol.
Old 12-30-2008, 07:10 PM
D4u2s0t's Avatar
we took orngbalts off to get the header on there. since it was flashed off there was no sense in leaving it on. we left something on the car though, just seemed like a pain to take off and didn't affect anything
Old 01-02-2009, 12:39 PM
Raiden8816's Avatar
So I threw another CEL last night, I'm gonna scan it when I get to work. If its P0442 again what should I do? Do I get a smoke test on the exhaust or what?
Old 01-02-2009, 01:05 PM
Maven's Avatar
p0442 is the EVAP system, not the exhaust. Youll need to interpret the failure record and see whats going on, or do a smoke test of the EVAP system and see if theres a physical leak.
agentirons
10-16-2015 02:11 AM
Delta coupe
09-30-2015 08:11 AM
katahdin_lubricants
09-20-2015 07:24 PM
Getaway_Driver
09-08-2015 09:41 AM
Quick Reply: Need exact proceedure in removing SAI
