in need of headers for a 07 cobalt Lt?
Old Sep 20, 2007 | 03:46 PM
zerodead0's Avatar
06 headers wouldnt fit.
Old Sep 20, 2007 | 03:49 PM
3fo893013L's Avatar
it's "header" and not headers. Also, most 06's didn't have SAI (although "some" did). I am unsure how it won't fit? It's the same header with the addition of SAI.
Old Sep 20, 2007 | 04:09 PM
zerodead0's Avatar
than would u know where i can find them because i cant find them anywhere
Old Sep 20, 2007 | 06:57 PM
shawn672's Avatar
All the headers are the same size...2.0, 2.2, 2.4..they all connect to the block the same.
I doubt he has SAI, he is in FL, so fairly good chance he doesnt have it, but you never know. Look at your stock header, and tell us if there is a small port where a connector is supposed to go in, that will mean you have SAI.
Old Sep 20, 2007 | 07:12 PM
06Pursuit's Avatar
right here man
Old Sep 20, 2007 | 09:02 PM
YSUsteven's Avatar
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/aftermarket-l61-cobalt-parts-27680/
Old Sep 20, 2007 | 09:53 PM
chipmonk212121's Avatar
man you must have that new v4 ecotec
Old Sep 20, 2007 | 11:13 PM
Halfcent's Avatar
I'm old school
What makes you think that 06 model headers will not fit your car? They should fit fine.
Old Sep 20, 2007 | 11:30 PM
Black07LS's Avatar
Check for SAI, if you doen't have SAI 05-06 should fit. https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
Old Sep 20, 2007 | 11:38 PM
Halfcent's Avatar
I'm old school
Not all of the 07 have SAI either. It is an option, and there are fewer that don't have it then do.
Old Sep 21, 2007 | 01:14 AM
kkanowitz's Avatar
Didn't some people on here also determine that the '07 2.2 manifold was almost the same as the '06 2.0 S/C manifold? That would explain the HP increase between the '06 2.2 and the '07 2.2.
Old Sep 21, 2007 | 09:33 AM
Halfcent's Avatar
I'm old school
There wasn't a change to the manifold that I know of. There was a change to the shape of the exhaust ports in the head along with a different exhaust cam profile. But the actual plumbing was unchanging to my knowledge.
I wish the original poster would come back, because I'm guessing he has SAI and just doesn't realize that is the problem.
So if you are reading this, and you now see that is the problem, don't fret. You can still use an aftermarket header by removing the SAI system. Post up again if that is the case and we will direct you to the proper instructions.
Old Sep 21, 2007 | 10:26 AM
shawn672's Avatar
First off, there has only been 1 confirmed shop that will remove SAI and they're way up in Maine somewheres..
Second, the SS/SC Exhaust Manifold is the same Manifold on the 07 2.2 (and late 06's). The downpipe may also be the same, but it hasnt been confirmed yet.
Old Sep 21, 2007 | 10:58 AM
blktrax's Avatar
The 07's are using the SS/SC casting minus the drill and talp for the 02 sensor, the 02's are both in the DP.
I wasted $50 on the SS/SC manifold when I could have just hand ported mine. Inlet and and collector were measured exactly the same.
Old Sep 24, 2007 | 04:48 PM
zerodead0's Avatar
Originally Posted by 06Pursuit
right here man
yeah, the stock header looks like that with a triangular shape end while the one i ordered doesnt, would u mind telling me how the installation would work because my friend n i tried n it just wouldnt fit unless we were doin it the wrong way
yeah, the stock header looks like that with a triangular shape end while the one i ordered doesnt, would u mind telling me how the installation would work because my friend n i tried n it just wouldnt fit unless we were doin it the wrong way.
Old Sep 24, 2007 | 04:52 PM
SKDR112888's Avatar
in that case it needs to be welded in and its not a direct bolt up
Old Sep 24, 2007 | 05:05 PM
Spanky's Monkey's Avatar
the welding issue is the very reason i've ordered the ss/sc mani. i don't see the gains being that far off anyway considering the rest of my exhaust is 2 1/2 already from the flex pipe back.
go figure gm installs a 2 1/2 flex pipe on a 2 1/4 exhuast....
Old Sep 24, 2007 | 06:46 PM
MagCobalt's Avatar
I got OBX Racing header, they fit perfect. i'd put a picture but i dunno how. but they look just like that guys black one.
Old Sep 24, 2007 | 06:48 PM
HatedCobalt's Avatar
i nave an 07 LT2 and i dont have the SAI...
Old Sep 24, 2007 | 11:42 PM
zerodead0's Avatar
I ordered obx headers too but they just dont fit or im doing something wrong because the picture above is what i have, the stock have a triangular shape end while the obx only has too unless theres a piece missin, someone help me out here
Old Sep 24, 2007 | 11:47 PM
Gearblock's Avatar
I havent heard much of OBX but i do want a midlength header...can u hook me up with the site please?
zerodead, like they said, its prob a weld in type or u were spose to get a downpipe from the same company or sometrhing
Old Sep 25, 2007 | 04:14 PM
zerodead0's Avatar
so is the picture above showing that what i have is wrong or that its right, cuz if so than thats what i have, What is the whole purpose os the pic than
right here man
Can u give me specified directions on how u installed those headers because i have no idea, thank you, can u see the difference with the headers?i do
Old Sep 25, 2007 | 04:20 PM
D4u2s0t's Avatar
the one you have is not a direct replacement. it's not missing a piece. you have to cut your downpipe for it to fit. there's nothing else you can do. it fits fine, you just didn't cut the downpipe.
Old Sep 25, 2007 | 07:11 PM
07cobaltguy's Avatar
you need to cut, flair, and flange your orig dp or buy a new one designed for it.
Old Sep 26, 2007 | 11:57 AM
Gearblock's Avatar
^ exactly what he said. thats your answer.
