Need help
Old Nov 20, 2019 | 09:59 AM
Delossantos's Avatar
Need help
I have a Chevy Cobalt won't go in reverse what should I do to get this fix we're should I start at
Old Nov 20, 2019 | 10:00 AM
Advice
Coblet won't go in reverse what should I do to get this fix
Old Nov 20, 2019 | 10:20 AM
exninja's Avatar
did you try putting it into first gear first, then to reverse?
Old Nov 20, 2019 | 11:20 AM
Take off your cupholder and look at your cables
Old Nov 20, 2019 | 01:11 PM
Is it an automatic or manual? That would help...
Old Nov 20, 2019 | 02:14 PM
Advice
Advice it's a automatic
Old Nov 20, 2019 | 02:16 PM
Advice
I take cup holder off what cable do I look for and do to check
Old Nov 20, 2019 | 02:30 PM
Well being an auto that rules out the cables being a problem was referring to a manual transmission
Old Nov 20, 2019 | 02:46 PM
exninja's Avatar
Are you pushing the brake in?
Old Nov 20, 2019 | 05:12 PM
Advice yes I am
Old Nov 20, 2019 | 05:14 PM
Advice
no we're can I look up maunnel guide YouTube
Old Nov 20, 2019 | 07:31 PM
Get a code scanner and check for codes. Im not sure if you need anything decent to pull codes from the transmission on a cobalt or if a generic one will work. You probably have a valve body issue or reverse clutch is gone...
you can still drive forward fine?
Old Nov 20, 2019 | 10:42 PM
Yes it drives froward fine but sometimes it feels like it pulling I think this car was a flood car cause I see it's linking fulided
Old Nov 24, 2019 | 02:26 PM
C0balts5's Avatar
Reverse takes the most amount of pressure. First I would look at the fluid level and make sure it's topped off. Odds are it's low on fluid. If you top it off and get reverse back then look into the fluid leak
timhebert
Jun 13, 2017 10:33 PM
gwatson650
Sep 8, 2009 06:47 PM
CinciSS07
Aug 30, 2007 07:49 PM
