need help finding tach wire
Old Jan 11, 2007 | 05:46 PM
lil_kano's Avatar
i've gotten a lil help from ion ninja but i can't figure out exactly which one, im probably wrong, but i tink the colors are a lil different in the ions. Can anyone help me out to find the tach wire that i can tap in on for my traction control switch? thanks
Old Jan 12, 2007 | 03:22 AM
IonNinja's Avatar
the tan wire from this plug
if you have an 07 then I don't know because you have a different setup...
Old Jan 12, 2007 | 09:13 PM
IonNinja's Avatar
i'll see if i can get a closer pic for you...
Old Jan 12, 2007 | 10:02 PM
lil_kano's Avatar
Itz okay now. I took a closer look and decided to pul the wires out of the loom and found that the little peice that ws visible changed colors from the heat. I got it on now. I have a new problem now...it doesnt read my RPM right. It reads it, but just half of what it is. So if im at 3000rpm is show 1500rpm. so i set it up that way and it works fine. I would like it fixed though. If anyone can help. thanks. im not sure what it is...it might be my power source, i have it hook up to itz own cig lighter. or it might be the connection on the actual tach wire, im pretty sure tz hooked up good. i dunno at this point.
Old Jan 13, 2007 | 05:48 PM
lil_kano's Avatar
Bump. Can some one give me an idea of whats wrong please?
Old Jan 14, 2007 | 05:52 AM
IonNinja's Avatar
make sure you have it set to 2 cyl mode
Old Jan 14, 2007 | 04:22 PM
lil_kano's Avatar
what do u mean 2 cycle? Like the gears skipped or the tach signal setup?
I got it workin. I changed the tach signal setup and it works fine now. thanks.
Old Jan 15, 2007 | 04:30 AM
IonNinja's Avatar
no prob.
whatever u wire up to that plug has to be set to 2 cyl mode to read the RPM's properly...
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
agentirons
Oct 16, 2015 02:11 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
