Need Opinions on Next Mod (Dad's Paying)
Old Aug 18, 2006 | 05:31 PM
Roadrunner's Avatar
here's the situation, daddy dearest wants me to put more power at the wheels so he has offered to buy me a part for my car but it has to increase power.
I noticed this on Gravana, but the install instructions dont work, and i dont know if it will REALLY even make a difference.
http://www.gravanatuning.com/applica..._Regulator_Kit
Other ideas:
- Rsm Racing lightened crank pulley
- Ingalls torque damper
- Cams (but might be too expensive for dad's liking) http://www.levelzeromotorsports.com/...php?product=16
- Lightened flywheel (again maybe a bit of a stretch)
my estimated spending limits would probably be $200, but i could probably make up the difference if needed, but keep in mind i am still a student.
Old Aug 18, 2006 | 05:33 PM
RedBaseBolt's Avatar
Dads paying?
Turbo!!!!!!!!!
Seriously though, I would get an intake or exhaust.
Old Aug 18, 2006 | 05:34 PM
Grimlakin's Avatar
Do they make a turbo kit for the 2.2l?
Roadrunner's Avatar
Originally Posted by RedBaseBolt
Dads paying?
Turbo!!!!!!!!!
got em
In that case get your tranny flushed and filled with royal purple. I've seen it add up to 8 HP at the wheels of a camaro before.
Old Aug 18, 2006 | 05:41 PM
Roadrunner's Avatar
does that work with manuals vs autos, cause i drive a 5 speed, also how much is it? i may be able to get that and yet another mod if it's cheap enough.
Old Aug 18, 2006 | 05:45 PM
Well royal purple is expensive ****. I don't know exactly how much but for tranny fluid in Canada it's around $200 CDN. It works best for manual, you see the most gain.
Old Aug 18, 2006 | 05:49 PM
Peg-city SS's Avatar
I saw that Royal Purple thing too but it is just getting back a percent of lost HP from the tranny, and I believe the car was making about 600hp that made the 8 hp off of tranny fluid, so you would be looking at a 2-3 hp gain at best. And the fluid in the camaro was pretty crappy looking anyways.
Old Aug 18, 2006 | 06:33 PM
clumsykx's Avatar
If you fill it with water you'll get 10 hp!
Old Aug 18, 2006 | 07:08 PM
IonNinja's Avatar
get the Pacesetter armor coated header
or the TWM short shifter, it wont add more power but it'll help cut your times down.
Old Aug 18, 2006 | 07:12 PM
SilverBalt's Avatar
yeah to both of those ^^^^ my header will be at my house tomorrow and in my car about 2 hours after i get it, and i absolutly LOVE the twm short shifter.. because i dont think the fuel regulator would be a big help for you unless u had alot of other work done to the car
Old Aug 18, 2006 | 08:32 PM
YSUsteven's Avatar
Just get an intake or exhaust, intake should be around $200 and is good for a few horses. Only exhaust I have seen cheap is the pace setter.
Old Aug 18, 2006 | 08:37 PM
NJHK's Avatar
Don't waste your money on the FPR. There is no need to try and raise your fuel pressure if you don't need more fuel. If you don't know if you need more fuel, than don't touch it. More than likely, you don't need it if you're not beyond bolt ons...when you start touching the inside your motor or working with boost, than fuel starts to become an issue but right now in this part of the game, your computer is capable of adjusting to the air changes decently.
If you seriously want to fine tune, I would use something more electronic like an HP Tuners (when it's available) or an SAFC2. Other than that, I wouldn't mess with your fuel pressure.
Old Aug 18, 2006 | 08:41 PM
g5mike's Avatar
If your dad is paying, then get a truck so you dont have to take the car out on rainy days
Old Aug 18, 2006 | 09:24 PM
joeworkstoohard's Avatar
give me $200 and i'll take you for a ride in my 2.4
Old Aug 18, 2006 | 09:36 PM
D4u2s0t's Avatar
go with a header...
Old Aug 18, 2006 | 10:42 PM
lightinbalt's Avatar
^^^^^Im with him^^^^^
Old Aug 19, 2006 | 07:55 AM
SilverBalt's Avatar
deff the header and maybe a high flow universal 2.25 in and out cat from magnaflow.. thats what i want to get soon, i have a header coming today, and i want to order the cat when i find out what part number it is from my friend
Old Aug 19, 2006 | 12:25 PM
Switt23's Avatar
Some cheaper stuff if you wanted to get more out of your money, although from the sounds of it, a header is going to get you the most performace wise.
Urethane Control Arm Bushings
Urethane D Link Bushings
Stiffer motor/torque mount (This can cause the car to vibrate a lot more, you'll have to decide if it's worth it or not.)
Personally though, I would stick with what most of the guys are saying. If you have an intake and you have an exhuast, get the middle man... a header!
Old Aug 19, 2006 | 12:48 PM
Bad06SS's Avatar
I say header or underdrive pulley.
Old Aug 19, 2006 | 12:55 PM
cobss187's Avatar
give me 20 and ill take u for a ride in my 2.0, i bet you'll like it better than the 2.4! No but seriously go with a header, you already have an exhaust and the header seems to be everyones choice including mine. Go for it
Old Aug 19, 2006 | 02:13 PM
how about use the $200 for entry fees at the local strip and get the driver mod???
Old Aug 19, 2006 | 02:40 PM
savior's Avatar
or save up 200 more dollars and buy some nice tires... rev higher then normal and you'll shoot off that line
or if you wanna save up 300 more and spray n20 in your car you'll also shoot off the line
bbuuttt... if you can only spend 200 dollars i'd get a short shifterand then use the remaining money to buy gas lol
Old Aug 19, 2006 | 03:38 PM
SIMMONS 2.0's Avatar
WOW theres alot of suggestions on here! most are ok but some are just dumb...honestly i have the injen CAI and DC Sports cat back and i got pretty good gains...u can get both for like 800 shipped...thats my recommendation....better sound than pacesetter too...not as ricey...much deeper and mellow
Edit: u have exhaust so intake and/or header
Old Aug 19, 2006 | 08:46 PM
Roadrunner's Avatar
sorry i didnt specify my mods, i have all my bolt ons done. Injen intake, Pacesetter ceramic coated header, corsa touring exhaust. I also have a short throw shifter and a dc strut bar.
I was talking to my dad tonight while giving his car an oil change and suggested a radar detector, he just laughed and said no.
I am leaning towards getting a crank pulley but dad doesnt want to give out credit card info online so i might get it and he will just pay me back, anyone else done this mod with good results? any other suggestions?
