Nitrous
haha yaeh
i honestly have no clue what to do with wiring the window switch or any of that..i can mount my bottle and run the lines. ha
im not gonna lie..i probably wont do alot of work..besides hiding wires. ha im **** bout that
but its a learning process. ahh well.
i've done this a coupla times. take your time and most importantly check and double check everything. best advice i can give is to get the basic nitrous system wired up and tested. once you know it works then you wire in the window switch and the rest of your goodies that way you can more easily trace any problems back to the source.
oh yeah make sure you have a clear idea of exactly where you want your noids and how you want the wiring ran. you also want to know where your switches will be. I'm running the nitrous system, bottle warmer and a purge as far as in dash switching goes, my window switch is under the hood. you want the switches in a convenient spot where things won't get turned off or on back accident.
check my vbgarage for pics.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
ncstateredline
Sep 10, 2015 07:22 AM
