Obx Header
Old Feb 24, 2009 | 02:23 PM
*S!CC_R@c!NG_TURTL3*'s Avatar
Obx Header
alright so i just installed my 4-1 obx header dp combo on my 07 cobalt..there was a couple of little modification that had to be made on the flange that bolts to the block but other than that it went on fairly easy... the only problem im having is that when i accelerate i hear a tinking sound... but only wen i accelerate.. i thought it might be the gasket but it was fine... has anyone else incountered this problem ??? im about to start bottle feeding this bad boy but wanna solve this problem first.. thanx
Old Feb 24, 2009 | 02:25 PM
SlowBalt_06's Avatar
exhaust leak from the ball joint
Old Feb 24, 2009 | 02:34 PM
theres no ball joint on these headers.. its the 2.4 header dp combo... its driving me crazy
Old Feb 24, 2009 | 02:54 PM
thisperishedmin's Avatar
Old Feb 24, 2009 | 10:54 PM
tinknocker's Avatar
if you a cat that might be it my res keeps coming loose on the inside and makes like a rattling sound
Old Feb 25, 2009 | 07:33 AM
no its catless... but the car runs like a champ... it really opened the car up
Old Feb 25, 2009 | 08:43 AM
pykie's Avatar
Under acceleration, your motor moves witch can caus ethe exhaust hit off the floor, firewall, heat sheild, and the rear axel, check the clearance, and while the car is in the air get a friend to rev it for you and see if it happens then
Old Feb 25, 2009 | 08:48 AM
maybe its hitting the metal coolant line that i had to beat up to get it to fit anyone else have this problem ?
Old Feb 25, 2009 | 09:21 AM
pykie's Avatar
you beat a coolent line?
you mean the heater core lines that got into your fire wall right?
Old Feb 25, 2009 | 09:28 AM
yeah sorry thought it was a coolant line
Old Feb 25, 2009 | 09:48 AM
pykie's Avatar
Do you have Coolent on your floor yet then?
i would be very careful with that.
Old Feb 25, 2009 | 09:56 AM
na i check every night after i come home from work no leaking and coolant is still full... i guess ima get under neath her to see if the vibration is coming from the heater core line hitting the header
Old May 18, 2009 | 01:51 PM
nikebaseballx00's Avatar
i dont plan on beating any coolant line if i install it
Old May 18, 2009 | 03:34 PM
Jn2's Avatar
Jn2
I beat my line..2 Gita from a 1/2" drive rachet and it was good, it's a hard line u can hit it to move it over, I've done it to 3 other cobalts already...no harm as long as u do it right
hacadacalopolis
Oct 28, 2015 06:09 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
