oil level fluctuation?
So today i was driving and i noticed the temp creeping up and the top end getting loud so i pulled over in a flat area and noticed no oil on the dipstick so i double checked that i had no oil and still had no oil so i drove to my buds house to put oil in so i could get some so i could drive home then we checked and it was back up to half, then once i got home it was back up to full... Where the hell is it going? or is there something wrong?
Like suggested, look under the oil fill cap for any sludge, then pull that valve cover to check the drain back ports
Were you on level ground when you checked the oil each time? How long after you shut the engine off did you pull the dipstick or did you check it with the engine running? If I recall correctly checking the oil right after engine was running it will typically read about 1/2 way down from full if full. It takes a while for all the oil to drain back down.
Glad to hear that before I gave it a try, I'll take the valve cover off and see whats under and maybe clean it manually if i can and maybe check valve lash since i'm in there
