Ordered my Pacesetter Cat-Back
Old Sep 1, 2006 | 12:41 PM
ted5986's Avatar
hey. ordered my pacesetter cat-back a few days ago. traking says it will be here on wednesday. cant wait. i will post a video or at least some pics when i get done
Old Sep 1, 2006 | 12:44 PM
D4u2s0t's Avatar
i have mine and love it!! sounds great, and was a very easy install... took less than an hour to get the old one off and the new one on...
Old Sep 1, 2006 | 12:48 PM
ted5986's Avatar
did you cut the old one or just unbolt it and pop it out?
Old Sep 1, 2006 | 12:50 PM
D4u2s0t's Avatar
the old one is welded together, so you can't unbolt it... i had to cut it twice because there wasn't enough clearance to get the pipe up and over the rear axle...
Old Sep 1, 2006 | 01:13 PM
ted5986's Avatar
gotcha cool thanks now i know that maybe i should go down to my dads shop and throw her on the lift instead of in the driveway
Old Sep 1, 2006 | 01:23 PM
D4u2s0t's Avatar
yea, my dad has ramps, so i used his driveway.. otherwise it's really hard to get under there and see what you're doing...
Old Sep 1, 2006 | 02:04 PM
1SloBowtie's Avatar
I used a lift, very easy. Cut your stock just in front of the axle and it'll slide right out. You also may want to spend a few extra bucks and get some bigger bolts. The bolts it comes with to bolt up to the rest of the pipe, are kinda puny for the holes they're going into.
Old Sep 1, 2006 | 02:19 PM
BlkSS4dr's Avatar
yeah I had to cut mine too...Would be much better with a lift. But, Ilove the sound and the fittment was great...Good luck and Have fun
Old Sep 2, 2006 | 01:30 AM
ted5986's Avatar
well i gues fedex wanted to be special because it came in this morning instead of wednesday. my dads shop was busy today so i did it on jackstands. you better believe 45 mins after the box hit my porch is was on my car. i love it. it sounds great and it fit on pretty easily. just unbolt, cut and remove. then bolt adn bolt and bolt and vrooooom!!! i am excited!!
Old Sep 2, 2006 | 01:44 AM
1SloBowtie's Avatar
Did you use the bolts it came with or did you pick up some thicker ones?
Old Sep 2, 2006 | 11:41 AM
ted5986's Avatar
i noticed the bolts were small so i went out and picked up larger ones.
thanks
Slick_Nick
Sep 28, 2015 09:15 PM
ashalle2
Sep 27, 2015 03:28 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
