P2AO1 code?
Old Jun 10, 2012 | 06:25 PM
Balto82's Avatar
P2AO1 code?
Got this code after installing dorman defouler?
Old Jun 10, 2012 | 06:28 PM
TommyP's Avatar
AWD > FWD
tried searching the site but there is literally nothing. Someone mentions it in a 5 year old post but no one knows what it is. I would undo whatever it was you did and see if it goes away.
Old Jun 10, 2012 | 06:36 PM
Balto82's Avatar
If I undo what I did then ill get a 420 code again lol. I read something on another forum about a bad o2 or wiring IDK.
Old Jun 10, 2012 | 07:07 PM
TommyP's Avatar
AWD > FWD
I don't understand what you actually did, did you try to do a hardware or software bypass of the rear 02?
Old Jun 10, 2012 | 07:37 PM
Balto82's Avatar
Well I installed zzp 2.5 dp got the 420 code within 10 miles. Than I decided to do the defouler trick. Never got the 420 code again even after 100miles. But then I got P2Ao1 after 100 miles. Just put on vibrant defouler will see what happens. Ill get a new sensor go from there I guess. What happens if tune tune out the P2AO1? Will the rear o2 still work? Will I be able to get the monitor set ready for rear o2? Can't delete rear o2 cause of emission. So if I can't figure out the downpipe thing I'm pretty much done with this car. I don't feel like taking everything off every year its pointless!
Old Jun 10, 2012 | 07:48 PM
cobaltss#01's Avatar
P2 it says generic(sae) but i can't find anything else yet.
Old Jun 10, 2012 | 07:54 PM
Balto82's Avatar
What does generic code mean? The only thing I have found was on a forum. Was talking about bad sensor or wiring. Was talking about testing the rear o2 for resistance for something like that, also leading down to a bad ECM
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
