Pistons for N/A
Pistons for N/A
Now, i have decided that i want to go the N/A route possibly nitrous, and somewhat beable to retain my warrenty. anyways here are my questions.
1. I am going with Comp Cams Stage 2, if i want to go with a higher compression ratio would the cams still work?
2. Going with a Higher Ratio, would i need standalone tuning to compensate?
3. Would i be able to run nitrous with a higher ratio, or would i run into problems?
Or should i just go forged with stock compression ratio?
Thank you all.
Thank you all.
Thank you all.
Thank you all.
yes
and yes
you can run high compression with after market cams fine, but you would need a way to advance/retard ignition timing and possibly tweak your AFR. I would suggest the SMT6, as it does better with timing than the FIC does since the FIC can only retard ignition timing.
realize however, that none of this will retain you warranty...if they see anything after market installed IN the engine, its pretty much void.
is it just me or does that not make sense? it wouldn't make sense to swap oem parts with oem parts and i agree with everybody that if you do ANY internal work, the warranty is out the window.
I am saying that if i blew a piston i could swap my stockers back in, mind you the cylinders arnt scored bad. thats what i was saying. but yes i am aware that the warrenty will be gone with this.
but yes he is right^
read the post.
oh im not really worried about the warrenty, i would have never even though about going that route, but my dads kind of weird even though he has nothing to do with the car, his name is no where on it.
but i do have experiance with engines and i do know what i am doing in most areas, ive been at this for a few years now.
Thank you all.
Thank you all.
