Problems with car. No codes?
Old Dec 5, 2012 | 01:20 AM
Balto82's Avatar
Lately my car has been doing weird things. Actually for the last 6 months and seems to be getting worse.car won't shift right. Car sounds different. Loss of power. Today when I turned the key once nothing was displayed on the cluster? Cluster not displaying at all now. The otherday I tured off the car and the rpm was jumping up and down to 1rpm. Think the computer might be messed up?
Old Dec 27, 2012 | 05:08 PM
ShaneBrady94's Avatar
Could be the wiring harness on the transmission. One of the wires might have a break in it. As for the cluster, I don't the problem is the cluster so I would check the wires going to it. If the wires aren't bad, then I would guess the problem would lie in the ECU. I am not a professional and I am not there to diagnose the problems, so this could be way off. So therefore I would take it to a professional. ZZP, a stealership, or something of the such.
Old Dec 27, 2012 | 05:15 PM
bykryder83's Avatar
PCM or bcm acting up or going bad. Could be a ton of things man. Check all your grounds as well. Or you could just simply need a new throttle body as that controls a lot. I'd say try replacing the throttle body and checking your grounds
Mods?
Last edited by bykryder83; Dec 27, 2012 at 05:15 PM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
