quick questions (08 2.2)
Old Sep 18, 2008 | 07:53 PM
wbrevels's Avatar
i hear I have an LSJ header stock, would you recommend upgrading the header and DP to something like zzp or vibrant if I were to do the 2.4 intake manifold swap? or would an LSJ DP be enough flow without being restrictive? (I have a DC sports 2.5" exhaust which is 2.5" OD and 2.25 ID. thanks for the help.
also i read ppl get 42 mpg having CAI, EXH, H/DP, 2.4 man, + tune on their 2.2's, is that true? 42mpg sounds really high. I would do that just for the extra ummff and fuel economy, but i do realize i'd have to run 93 oct.
WHAT ARE THE DEMENSIONS OF THE LSJ DP????
Old Sep 18, 2008 | 07:56 PM
Scythe_Snake's Avatar
Originally Posted by wbrevels
I have an 08 cobalt LS, i think i have the L61 but what is LES?
also i hear I have an LSJ header stock, would you recommend upgrading the header and DP to something like zzp or vibrant if I were to do the 2.4 intake manifold swap? or would an LSJ DP be enough flow without being restrictive? (I have a DC sports 2.5" exhaust which is 2.25 ID. thanks for the help.
thanks for the help
1. LE5 is the 2.4L found in the Sport/ 2.4L SS
2. its kinda of up to you. aftermarket is better.
Old Sep 18, 2008 | 07:59 PM
wbrevels's Avatar
thats what i thought, but having a 2.5"/2.25" ID exhaust, arent the LSJ header the same diameters? so going any larger would my exhaust just restrict it?
Old Sep 18, 2008 | 08:04 PM
I am not sure what the stock LSJ header diameter is.
But i know after market wise you want to stay below 3 inches unless you have plans for 300 + whp. Most exhausts for cobalts are 2.5", the gmpp/borla are the only ones i know about that are 2.25"
Old Sep 18, 2008 | 08:06 PM
Jn2's Avatar
Jn2
suscribed for answering when i get home
Old Sep 18, 2008 | 08:09 PM
wbrevels's Avatar
yea my exhaust is a "so called" 2.5" but that's measuring the OD, the IS is really 2.25".... so i have to reasearch and find if the LSJ PD is 2.25" ID because if it is i think that's the way to go because i'm building an economy car for now until my warranty is up
sweetness
Old Sep 18, 2008 | 08:13 PM
Jn2's Avatar
Jn2
2.25" dp is fine, i have the vibrant mine is 2.5" my exhaust is 2.5" od, 2.25" id
Old Sep 18, 2008 | 08:16 PM
sweetness
do you have pics? I believe the 07-08s have the LSJ header, but not the cat backs. The LSJ's have different cat backs I believe. pics would be helpful.
Sounds like you have the 2.2L one though.
Old Sep 18, 2008 | 08:19 PM
Jn2's Avatar
Jn2
he has a aftermarket exhaust, intake, wants to know if he should get a aftermarket dp or just the lsj dp i think, i ddint read it all as im too lazy and he made it quite long
Old Sep 18, 2008 | 08:21 PM
OK i TOTALLY got the incorrect drift of that.
My bad OP. I would suggest aftermarket myself.
Old Sep 18, 2008 | 08:36 PM
wbrevels's Avatar
my exhaus tis 2.5" OD, 2.25 ID, i'm curious to know the demensions of the LSJ DP becaus ei cant find it by searching, i'll keep looking but I'm guessing its 2.5" with about an inch at the end with 2.25" which sounds like it would work perfect for my exhaust
a 2.5" ID DP seems like it wouldn't help much because i belive the exhaust would restrict it being 2.25 ID.
that's exactly what i'm asking
Old Sep 18, 2008 | 08:46 PM
YSUsteven's Avatar
I went from 36 to 38 on the highway just from an intake and exhaust. If I also got a tune and header / downpipe, I would fully expect to get 40 mpg highway. The biggest trick is to drive the speed limit.
It it was a manual, I would believe 42 mpg, after all, I have an auto.
Old Sep 18, 2008 | 08:56 PM
wbrevels's Avatar
ok thanks, yea i'm seeing 32-34 cty/hwy avg. w/CAI + Exh which is higher then i was seeing, 30-31 stock
Old Sep 19, 2008 | 08:29 AM
RedBaseBolt's Avatar
Just get this combo,
ZZP header and downpipe.
You'll never look back.
Old Sep 19, 2008 | 01:04 PM
wbrevels's Avatar
thats the one I was thinking about because it's $550 shipped or alittle less bepending on how you want it, plus they give you $50 coupon for sending in your stock DP w/ cat,
when you were buying the dp did you buy it new? did you select the 2.5" flange?
Old Sep 19, 2008 | 07:22 PM
Maven's Avatar
Dont waste your money on the ZZP shorty header. Youll still need a DP, it doesnt have equal length runners, its got a big tapered step in the runners for 1 and 4, ans 2/3 just dump into the large collector tubes, the O2 sensor reads almost entirely off of the #4 runner, and its only $20 cheaper than their midlength which is MUCH nicer.( Idont mean to bash your combo Red, I just think for $20 the midlength is absolutely the way to go as far as ZZP is concerned)
I wish that someone made a nice mid-long tube header in 304 stainless with 1 5/8" primaries.
Red, is it just the picture, or are the primaries not welded to the flange on the outside?
Old Sep 19, 2008 | 08:37 PM
wbrevels's Avatar
thanks for all the help guys, i went with an LSJ DP for now.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
