running lean???
running lean???
alright i have a 2006 chevy cobalt ls, it has a custom turbo setup 50mm t3/t4 turbo, turbotech racing intake manifold, 39# injectors, open downpipe, trifecta tuned. ok i changed the oil and pressure sending unit to help my oil pressure issue it was pretty low. i got that out of the way and then i put it all back together, now im getting a lean misfire all the sudden i put everything back together perfect chack all the wire clips like 5 times, first thought it was spark, got new plugs,ICM nothing then i did some reserch and ppl said the first 02 sensor goes out, and i had a innovote wideband i just bought so i addapted it into my harness and got it connected into the first o2 bung hole on my downpipe. now i can see its a lean misfire it stars up fine for like 30 seconds then starts to misfire pretty bad it reads a a/f ratio of 14.1-15.1 at start then at misfire it gets to around 18.1-20.1 i have no clue whats going on i didnt do anything besides that maintenance to try to get it running and change the feed from the head to the block. please help if u have any info as to what it could be. i have talked to my local tuner i sent him some data logs of the start up and misfires and he cant find anything he says just looking for someone to point me in the right direction
