SC 2.2 bent valves/build
Old May 27, 2012 | 08:00 PM
1LowLS's Avatar
1LOWLS L61 Forged SC build!!!
Well timing chain tensioner took a **** and the intake cam jumped some teeth.Exhaust valves stayed in check though.Going to for ge the bottom end and do an extensive port job on the head/blower.Recommendations on valve springs? here's some shitty quality pix.
Old May 27, 2012 | 08:04 PM
jonathan923's Avatar
ouch sorry to hear man, i say you give zzp a call and order some goodies GL with all the fixing and rebuilding man
Old May 27, 2012 | 08:05 PM
TurboTechRacing's Avatar
Ouch...
We do have many engine build items also.
Old May 27, 2012 | 08:17 PM
1LowLS's Avatar
Thanks and yeah I have been checking out both ZZP and TTR.Probably going with TTR valvetrain as a turbo 2.2 here is running the springs and retainers and is working well.I have more research to do for the bottom end.Probably a Wiseco/Eagle combo.We will see though.I will keep this thread updated.
Old May 27, 2012 | 08:32 PM
mongorat427's Avatar
I have a new 2.2 head . Cheap
Old May 27, 2012 | 08:38 PM
Old May 27, 2012 | 08:39 PM
1LowLS's Avatar
what year?
Old May 27, 2012 | 08:43 PM
nhanson's Avatar
TTR matches pricing i think on piston/rods. They have Eagle rods and wiseco pistons.
Make it bulletproof!
Old May 27, 2012 | 09:20 PM
IonNinja's Avatar
You work fast
Old May 27, 2012 | 09:28 PM
OttawaMark's Avatar
Mongorat also has some LNF heads he is willing to part out, their valves are a significant upgrade.
Old May 28, 2012 | 01:43 AM
1LowLS's Avatar
Originally Posted by IonNinja
You work fast
This ain't my 1st rodeo son!
My heads fine.Just gotta replace the intake valves.but i'll end up replacing all the valves and springs.We'll see what happens though.I'm getting the valve spring compressor for it Tuesday so I can pull the head apart next.Until then it sits.
Old May 28, 2012 | 06:53 AM
Originally Posted by 1LowLS
what year?
Not sure of the year but theres a casting number in the picture
2.2 head new with valves and springs $150 plus UPS
Old May 28, 2012 | 10:10 PM
klutch814's Avatar
well... keep all the costs and stuff.. as i will probably start doing this also..lol
Old May 28, 2012 | 10:38 PM
1LowLS's Avatar
Will do.
Old May 29, 2012 | 02:20 AM
1LowLS's Avatar
Ordered the forged bottom end.Wiseco forged pistons,Eagle H-beam rods
Old May 29, 2012 | 11:15 AM
07cobaltguy's Avatar
Mongorat that is an 07-08 head. It has the cam sensor on the intake side of the head no other years had that.
Old May 29, 2012 | 11:31 AM
Brags's Avatar
Just a heads up if you decide to go with the supertech springs and retainers, it will require custom work to head and seats to work on an 07 2.2 head. If you send the stuff with your head when you get it p & p'd, it shouldn't be a problem for them to take care of.
Old May 29, 2012 | 11:40 AM
1LowLS's Avatar
I keep looking at it and it looks like a LE5/LAP head.
Cool thanks for the heads up.
Old May 29, 2012 | 12:13 PM
I dont see any extra room where the cam phasers would be on a LAP/LE5
Old May 29, 2012 | 12:23 PM
1LowLS's Avatar
look just left of the hook.It comes out.Mine doesn't do that.Plus the "PCV" port is way smaller than the one on my head.
Old May 29, 2012 | 12:41 PM
1LowLS's Avatar
here's a pic of my head
Old May 29, 2012 | 12:50 PM
Brags's Avatar
Definitely different, mogorats has two square holes inbetween 1-2 and 3-4 and two small round holes inbetween 2-3. Lowls has two rectangular holes between 1-2 and 3-4 and one bigger rectangle between 2-3.
Old May 29, 2012 | 12:56 PM
1LowLS's Avatar
yeah on his if you look just left of the engine hook you can see where it lopes out for the cam phasers. no VVT on mine
Old May 29, 2012 | 01:04 PM
Brags's Avatar
Got me curious here's a few snaps of mine.
Same holes as yours, Im 07 as well
Old May 29, 2012 | 01:16 PM
SatanzSS/SC's Avatar
I have some supertech valves brand new in the box if you're interested.
