SC 2.2 bent valves/build
Old Jul 1, 2012 | 12:36 AM
  #101
FF_ace's Avatar
well damn i will make the switch then
Old Jul 1, 2012 | 12:42 AM
  #102
1LowLS's Avatar
he told me non detergent for break in then you can run synthetic after.he runs 20w-50 in his car.
Old Jul 2, 2012 | 02:54 AM
  #103
1LowLS's Avatar
Pulling the balancer and timing cover tomorrow to retime the engine again.I got another tensioner today thinking maybe i got a faulty one since the motor would sound good at idle but once at 2000 rpm or higher,sounded like the chain was slapping around.As pulling the old one out,the chain made a loud noise on the crank end.So before trying to crank it with the starter I pulled the plugs and spun it by hand and you can tell the valve is tapping the piston.Lucky I checked by hand 1st.I would be pissed if I had to do this all over again from my own ignorance.
Old Jul 2, 2012 | 10:14 AM
  #104
Axelthered05's Avatar
ok so let me ask a question, in order to properly time the engine after reasembly do you simply line up the marks on the chain/cams/crank
Originally Posted by 1LowLS
She's getting there.
Old Jul 2, 2012 | 12:20 PM
  #105
1LowLS's Avatar
yes.They crank gear has a dot that should be in the 5 o clock position and then there is a pink mark on the chain to line up with that while also lining up the top 2 marks as pictured
Old Jul 2, 2012 | 12:38 PM
  #106
AzraelRaezier's Avatar
so you just spin the crank's white dot to 5 o clock and then put the red link on it and then wind the chain up and on the back side spin the cams so the exhaust triangles on the red link and spin the front so the intake triangles on the green? then put tensioner in?
Old Jul 2, 2012 | 02:24 PM
  #107
Old Jul 2, 2012 | 08:57 PM
  #108
1LowLS's Avatar
well got it running,then popped on the MIL(CEL for others here).Scanned it with my Android stupid phone(smart but suxass) and its throwing a crank to cam position correlation which means timing yet again jumped but this time only one tooth so no damage was done.So I have to pull the cover yet again to re time it YET again.Ive timed my motor maybe 20 times now.It's to the point where I think the chain may be stretched.Im annoyed so it will sit until I feel like looking at it,yet even think about it again.
Old Jul 2, 2012 | 09:02 PM
  #109
FF_ace's Avatar
That sucks man but cant wait to see this running again... I talked to cris made the switch to valvoline 20-50 race synthetic
Old Jul 2, 2012 | 09:06 PM
  #110
1LowLS's Avatar
yeah I dont like valvoline.Ill stick with castrol.itll probably be running next year as im tired just thinking about the car lmao.
Old Jul 2, 2012 | 11:47 PM
  #111
I would do a crank case relearn before you tare it all apart again
Old Jul 3, 2012 | 01:42 AM
  #112
1LowLS's Avatar
No crankcase relearn here bud.plus I never pulled the ECM or touched the crank sensor.
Old Jul 3, 2012 | 11:22 AM
  #113
klutch814's Avatar
your ass better have this running by the time i come out there because i wanna see it!
Old Jul 3, 2012 | 12:02 PM
  #114
bluebalt07's Avatar
I feel ya on timing the damn thing over and over. I could probably do that **** in my sleep by now.
Old Jul 4, 2012 | 02:42 AM
  #115
1LowLS's Avatar
I know right!?!?! lmao.
When are you coming out here? I bought a new chain for it today but won't put it on until next week and then it SHOULD be good to go.......Should!
Old Jul 7, 2012 | 06:19 AM
  #116
1LowLS's Avatar
Going to pull the timing cover and valve cover after work today and get started on replacing the timing chain.I miss driving her so I need to get her dialed in.
Old Jul 9, 2012 | 04:49 AM
  #117
1LowLS's Avatar
I took my car for her 1st drive.Ran excellent,drove well.Took her to 4200 at 5 psi.She really wants to go,I can feel it.Did a lot of stop and go running only 5 psi,lots of decel.Ive missed driving her so much,it was nice to drive my car with a built motor that I assembled.The feeling is fantastic of success and accomplishment.Im uploading a video now.
Old Jul 9, 2012 | 06:29 AM
  #118
1LowLS's Avatar
WARNING!!12 MINUTE VIDEO OF NOTHING EXCITING!
Forged 2.2L SC cobalt 1st drive! - YouTube
Old Jul 9, 2012 | 11:11 AM
  #119
klutch814's Avatar
sounds good man!
Old Jul 9, 2012 | 01:39 PM
  #120
1LowLS's Avatar
Thank you
Old Jul 10, 2012 | 04:42 AM
  #121
1LowLS's Avatar
Forged 2.2L SC Idle. - YouTube
Went Half throttle to 4500 rpm which was ~8psi.I don't remember it pulling that hard at half throttle.Im excited to full out.
Old Jul 10, 2012 | 11:00 AM
  #122
klutch814's Avatar
wrong vid?...
Old Jul 10, 2012 | 02:38 PM
  #123
1LowLS's Avatar
No I don't have a video of that.
Old Jul 10, 2012 | 08:43 PM
  #124
1LowLS's Avatar
3/4 throttle 2.2 SC - YouTube
Old Jul 10, 2012 | 09:42 PM
  #125
klutch814's Avatar
lookin good man now you need a turbo and moar boost
