SC kit first start up. WONT START! HELP!
Old Jun 9, 2010 | 12:12 PM
Bolted-N-LoweredSS's Avatar
you could of checked it without switching it also the video doesnt seem to be working it says page not found when i click it write a clear update of whats happening right now maybe we can all find out what it is
Old Jun 9, 2010 | 12:14 PM
myrt's Avatar
u need a tune man then it will start
Old Jun 9, 2010 | 12:16 PM
wbrevels's Avatar
read before you post, its tuned. we established that an our ago.. my bad but thi sisall i needed right now. i need to know whats wrong.
fixed link and updated first post
Old Jun 9, 2010 | 12:17 PM
Starting the car with 60# injectors and no tune wasnt the best idea...I think if you loaded the tune before you tried to start it the first time it would of started however other people started theres up before the tune but not sure if they were running 42# injectors or not hmm
Old Jun 9, 2010 | 12:18 PM
cobaltguy889's Avatar
Link to photo didnt work. use [IMG] [/IMG] format
sigh...never replace a fuse with a bigger one. who knows what you burned up now
+1
Old Jun 9, 2010 | 12:24 PM
you put ur normal fuse back in that wasnt from your rear defroster..
Old Jun 9, 2010 | 12:48 PM
wbrevels's Avatar
yea all the fuses are in the right place now and theres no engine codes.. but when i started it i had the rear defog fuse in the place of the fuel pump, its bigger
fixed the link again, uploaded to youtube because photobucket is being stubborn see the first post.
Old Jun 9, 2010 | 12:49 PM
trey ss's Avatar
ouchh
Old Jun 9, 2010 | 01:06 PM
coopercharge's Avatar
sounds to me like you may have fried the fuel pump and like I said earlier check the relay, that should have been bulled while running to let it bog down before you put the new injectors in.
Old Jun 9, 2010 | 01:14 PM
383_Stroker's Avatar
Unless it popped the original fuse for the fuel pump. and then you put the bigger one in there.. there's no reason to believe the fuel pump is fried...
if there's no problems with the systems.. it doesn't matter if you put a 100A fuse in the slot..
Old Jun 9, 2010 | 02:28 PM
  #36
wbrevels's Avatar
Ok so i switched relays, not fuses.. the 15A fuse for the fuel pump is not blown. I originally had my water pump plugged into the relay for the fuel pump, not the fuse, i took the relay from the defog and used i for the fuel pump relay. i dont know where to look. it doesnt sound good when i tryto start it.. might be the starter?
Old Jun 9, 2010 | 06:40 PM
  #37
krautsalat's Avatar
wheres your ground for the h/e pump?? If you have it tied with the fuel pump your car will not start or turn over, I just experience the same problem when I did my swap. check your ground...its shorting the fuel pump
Old Jun 9, 2010 | 10:04 PM
  #38
wbrevels's Avatar
i grounded the H/E to the bolt holding the HE pump.
Old Jun 14, 2010 | 04:23 PM
  #39
Did you get it started yet?
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
