Sentry's Turbo Build Thread Extravaganza!
Old Jan 20, 2009 | 01:16 PM
Sentry's Avatar
Sentry's Turbo Build is Complete!!!
I was going to wait a bit and start this a couple of days before the install, but I figured while I'm bored sitting here at work I could at least put something up if only for inventory's sake. This is going to be my log of everything since I have an absolutely terrible memory.
Turbo build set for 01/28 - 01/31!
What I've got on so far:
  • Full Garrett T3/T04E 57 trim .63 A/R with stg 3 wheel
  • TiaL 38mm Wastegate set at 7 psi
  • Vulcan intake manifold powdercoated black
  • Vulcan turbo manifold w/external WG flange
  • 42lb Injectors
  • 27" Intercooler (thanks to psycho cam)
  • Zeitronix wideband & datalogger
  • Hayden auto tranny cooler
  • 2 full sets of 2.5" IC piping (thanks to elec blue)
  • RFL bov adapter for 2.5" piping
  • Intake adapter for MAF sensor
  • ZZP catless DP with 2.5" outlet
  • LSJ catback
  • (x2) 3.0" to 2.5" silicone reducers for MAF adapter pipe
  • (x1) 3.0" to 2.5" silicone reducer for 3" filter adapter pipe
  • Autometer boost gauge in 3 gauge pod
  • 2.5" to 2.0" silicone reducer for compressor outlet
  • 2.75" to 2.5" silicone reducer for turbo intake (don't ask)
  • NGK Spark Plugs Iridium (BKR7Eix) 1 step colder gapped to .034"
  • MAF adapter at autozone
  • Turbo XS RFL bypass valve
  • 12ft of vacuum lines
  • Oil lines and fittings
  • O2 Bung for DP
  • Heat wrap for manifold
  • Ecotec exhaust flange from zzp for custom DP
  • 3" filter adapter
  • T3 gasket
  • Turbo back dp
Waiting to go on:
Nothing!
What I still need:
Nothing!
I took off 2 days around my 2 days off, which is going to give me 4 whole days to work on it starting on Wednesday, 01/28th spanning Saturday, 01/31st. I expect to have everything on by wednesday night, and tuning will start the following day until Vince gets it perfected. I have a wideband, so no worries, he'll have it set to a T by fri/sat I'm sure.
Here's some pics for your viewing pleasure:
I'll update this when I get more parts in, I got a bunch of stuff sitting at the house that I'll take pics of once I get it all in. And, like I said, build date is set in stone for 01/28th-01-31st, that's next week! I'm going to make this into a how to later, showing the important steps and the custom issues I ran into. Should be fun.
If you're wondering what I used to mount the intercooler, I went to a local hardware store and picked up two heavy duty metal shelf hangers and cut/drilled them.
Things to do:
  • Perfect the tune, datalog.
Old Jan 20, 2009 | 01:41 PM
PsychoCam's Avatar
Good luck with your build mine is taking me a little longer than expected. I will keep my thread updated aslo? Are u running water lines to the turbo? If so where are u getting all the fittings at to tie into the lines?
Old Jan 20, 2009 | 01:48 PM
Sentry's Avatar
Mine is oil cooled only, thankfully. You'll need to look up your turbo and maybe measure the ports to find the right fittings.
Old Jan 20, 2009 | 01:54 PM
PsychoCam's Avatar
Did u decide where u are putting your maf and bov? there was that one thread with so much discussion about that lol
Old Jan 20, 2009 | 01:57 PM
Sentry's Avatar
Yeah, off the intercooler after it makes that first bend up, that's where the bov will be. Maf adapter pipe will be about a foot away from the TB.
Old Jan 20, 2009 | 01:59 PM
PsychoCam's Avatar
so the bov will be on ur passanger side? I might just keep mine on the drivers side but I am not sure if it will be too close the the maf.
what made u go with a tranny cooler?
Old Jan 20, 2009 | 02:04 PM
Sentry's Avatar
It will be on the drivers side actually. Post intercooler. As long as they aren't RIGHT beside one another it's fine.
Tranny cooler is for my automatic, it's just extra protection and it lengthens the life of the transmission. It's a cheap safety mod.
I'll be making a how-to of my particular setup, for anyone that's interested. Stay posted.
nice well at least u are looking after your tranny! I dont know what to do with my injectors. Should i get the lsj harness and repin the connector for mine or just get the pigtales.
both can be bought at zzp i believe
I've heard it's really easy to just repin the injector clips, but I'm pretty good with a soldering iron, so I'll just solder them on.
I bought the injectors and harness from a guy on here for $120.
Old Jan 20, 2009 | 02:09 PM
PsychoCam's Avatar
Old Jan 20, 2009 | 02:20 PM
SUKXOST's Avatar
You plannin on a front lip or anything to hide that cooler?
Old Jan 20, 2009 | 02:23 PM
Sentry's Avatar
Heh, possibly. I was going to go with a SS bumper cover to show it off, but the sleeper look is good too.
Old Jan 20, 2009 | 02:26 PM
06_ion2's Avatar
you could spray it black it could stick out less than.. thats what im going to do
Old Jan 20, 2009 | 02:30 PM
SUKXOST's Avatar
I've got the Hahn FMIC and although it's pretty hidden...which I want....I kinda wanna take the front bumper back off and paint the front of that sucker white. Would pop out nice against the black mesh grill
Old Jan 20, 2009 | 02:32 PM
PsychoCam's Avatar
Is it ok to spray paint an intercooler? i wanted to make mine black
Old Jan 20, 2009 | 02:38 PM
06_ion2's Avatar
yes its ok but very very little..
Old Jan 20, 2009 | 02:40 PM
PsychoCam's Avatar
ok ya I just want to try an conseal it a little more.
Old Jan 20, 2009 | 03:14 PM
SUKXOST's Avatar
almost every IC on the market has thier brand painted on the front of it. I doubt it's a facny type of paint but yeah I would not go overboard with it.
Old Jan 20, 2009 | 03:25 PM
PsychoCam's Avatar
I am just usingthe injen cai bc the maf is already on that. I am not going to try and get the adaptor from zzp and weld it on
Old Jan 20, 2009 | 03:31 PM
Sentry's Avatar
Honestly, if I had the time I would probably go ahead and get either that one or the Cobalt addiciton one. If you just have the regular intake pipe, the couplers might slip off because the ends are not rolled to the tip. Meaning the coupler doesn't have a lot to hold onto.
You might wanna quaduple clamp that thing, lol.
Old Jan 20, 2009 | 03:43 PM
PsychoCam's Avatar
what does the rolled in on both ends do? did u get the weld one or the clap one?
Old Jan 20, 2009 | 03:55 PM
06_ion2's Avatar
the rolled ends help the clamps/couplers from slipping off under boost.. so it has somthing to catch on to stop it from coming apart
Old Jan 20, 2009 | 04:05 PM
Preston's Avatar
hmmm are you worried at all about slamming your IC on the ground if you hit a big bump?
Becuase once your lowered..that be close to the ground
Old Jan 20, 2009 | 04:30 PM
Sentry's Avatar
I'm already lowered 2.0"/2.5", don't know how much lower I could go, lol.
Old Jan 20, 2009 | 04:42 PM
Preston's Avatar
i just saw under your
Coming soon this in your sig..it said springs..so i didn't think yo uwere haha
well hope yo udont smash it hahah
Old Jan 20, 2009 | 10:56 PM
NOvelociti's Avatar
you should cut out those slats in the bumper under the plate so you still have the sleeper 2.2 look but have a little bit of show
Old Jan 21, 2009 | 02:21 PM
Nato09's Avatar
how many psi do you estimate reaching with this kit?
