Sentry's Turbo Build Thread Extravaganza!
Old Jan 27, 2009 | 06:54 PM
  #51
Sentry's Avatar
The rest of the parts come tomorrow in the mail, build starts in the morning for those that are following. Really excited!
Old Jan 28, 2009 | 02:25 PM
  #52
hugemurph4's Avatar
uh yea really excited
how big of a whole did this put in ur wallet so far
Old Jan 28, 2009 | 03:59 PM
  #53
Sentry's Avatar
Probably around 4,000. I could have done it a lot cheaper, but I have larger goals than what my stock motor can handle. For instance, the intake manifold was totally unnecessary until I up the boost. That's 550 right there, not to mention the turbo was a little pricey. It will all be worth it in the end.
You could have done a much smaller turbo with 2.4 manifold for around 2500-3000.
I have got the manifold on, changed the plugs. Waiting on the rest to come in, right now we're just chilling watching pinks on tv.
Old Jan 28, 2009 | 04:56 PM
  #54
Nato09's Avatar
nice! props my friend.
Old Jan 28, 2009 | 05:10 PM
  #55
PsychoCam's Avatar
def got to get some pics up since you are just relaxing
Old Jan 28, 2009 | 10:41 PM
  #56
vulcanturbo's Avatar
did the turbo and wastegate come in yet? I called my turbo supplier monday he said it would go out then... i called again today to double check, gave me a tracking number that wasnt working in UPS system, claimed it was for whatever reason but that it DID ship out, hope he didnt drop the ball on this one. let me know!
Want one?
Last edited by vulcanturbo; Jan 28, 2009 at 10:41 PM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 12:18 AM
  #57
Jn2's Avatar
Jn2
Hahaha I hope u mean a resevoir, not my manifold hahaha
Old Jan 29, 2009 | 12:28 AM
  #58
hugemurph4's Avatar
So if i were to F/I my car and only run about 5 lbs of boost is there anything like do i reeally need bigger injectors and a tune or can it run on 5 lbs no problem i know its a low number but hey money is tight and its my daily driver
OH and one more thing...DEF show off that intercooler there is nothing cooler than that look
well to each is own...
Last edited by hugemurph4; Jan 29, 2009 at 12:28 AM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 12:56 AM
  #59
mrsilent13's Avatar
no you cant run 5lbs on this engine too many sensors....when i first started i set my wastegate to zero until i could get it tuned...so if your going to turbo it...go for it set your wastegate to 0psi...and you will be straight until you can get a tune and bigger injectors...at leasts some 42's...but def do your research before you ask these questions
hey Sentry looking good...congrats on getting that oil cooler...the stock one sucks....i have a 4 pass hayden on my tranny...as for my build...i have no cash to finish at the time...still looking for a job...and still waiting on my last check from the marines corps...so once i get my last check im sending my car to the shop to get it back on the road...then to tune it for 12-14lbs....until i can get a different manifold that will hold more boost...good luck gettin this finished...your going to luv it
Last edited by mrsilent13; Jan 29, 2009 at 12:56 AM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 01:13 AM
  #60
Sentry's Avatar
Well, if any of you guys are still awake, I'll run an take some quick pictures.
Long story short, UPS lost my package today in Tennessee somewhere, so my 2 day air was for nothing. The turbo, manifold, wastegate, oil lines, and vacuum hose is supposed to be in tomorrow prompt. All I did today was the essentials: removed headers, replaced spark plugs, installed maf adapter, finished routing the IC piping, installed the vulcan intake mani, installed the 42's.
Checklist for tomorrow: Drill and tap oil pan for return, install header, turbo, solder injector harness, hook up the pipes and then tow to exhaust shop and I'll be complete.
Pic of the vulcan manifold on.
What I'm focusing in on is the bov adapter pipe.
This is the MAF adapter I told you guys I was getting at autozone. It ended up being like $30, have to order it though. part number 9405. I had to zip tie the radiator hose out of the way, it ended up being right over where I needed to complete the tubing up.
Old Jan 29, 2009 | 01:27 AM
  #61
mrsilent13's Avatar
is that going to run ok...with the sensor in that position? why didnt you leave it on the intake pipe going to the turbo?
Old Jan 29, 2009 | 01:31 AM
  #62
Sentry i tried to call UPS but appears there not there right now.. to late i guess? Ill call tomorrow, there was no reason for that package to not been there today! Hopefully i can talk them into refunding me or something!
Looks really good so far!
Old Jan 29, 2009 | 01:32 AM
  #63
Sentry's Avatar
Because my blow off valve is atmospheric only. If I run it draw through like that, every time my bov actuates I will run super rich because the sensor is reading air that is no longer there. My maf adapter is 3", so no worries. This is actually the preferred method when doing atmospheric bovs.
Old Jan 29, 2009 | 01:34 AM
  #64
elecblue06's Avatar
looking good man.. good to see my IC piping goto a good cause can't wait for running vids..
oh and just a bit of advice did you use hair spray on the pips ? that'll help it not slip off and cause boost leaks
Last edited by elecblue06; Jan 29, 2009 at 01:34 AM. Reason: Automerged Doublepost
  #65
Sentry's Avatar
That will be tomorrow. I won't be pushing it hard at all though, just short trips up the street and back.
What the ****? Hairspray? No offense, but that sounds like a good way to blow something up if those fumes build up in the pipes.
Does that really work?
Old Jan 29, 2009 | 01:40 AM
  #66
elecblue06's Avatar
good **** man.. you gonna be up for a bit? mind a quick chat on aim about some things? definitely don't beat on it too hard right now you need a break in period
that intake manifold manifold is smecksie
lol
Last edited by elecblue06; Jan 29, 2009 at 01:40 AM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 01:42 AM
  #67
mrsilent13's Avatar
i run an atmospheric bov...and i have my sensor on the intake pipe just like the new tc does...and never had an issue with it going rich everytime it blew off. ran perfectly fine..but its up to you...its looking good
ha thats a good idea...the hairspray will help it stick...thanks for a good idea
Last edited by mrsilent13; Jan 29, 2009 at 01:42 AM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 02:05 AM
  #68
elecblue06's Avatar
yea it was a tip i got from paul or someone lol ingenious isn't it lol
Old Jan 29, 2009 | 02:41 AM
  #69
SloBaLt RiDeR's Avatar
subscribed
Old Jan 29, 2009 | 09:24 AM
  #70
Preston's Avatar
Jesus your manifold looks awesome JN2 hahahah sorry for totally wrong topic in your thread sentry
looks good tho!
Old Jan 29, 2009 | 09:43 AM
  #71
06_ion2's Avatar
intake mani looks awesome dude. i cant wait to get home to put mine on along with a 2.4tb
Old Jan 29, 2009 | 09:47 AM
  #72
elecblue06's Avatar
yea it'll look more comfy in our ions though more room
Old Jan 29, 2009 | 10:15 AM
  #73
06_ion2's Avatar
and room for the sexy procharger
Old Jan 29, 2009 | 10:25 AM
  #74
MadBrad's Avatar
Looking good. Make sure to get lots of pics of the install, and beer
Old Jan 29, 2009 | 12:31 PM
  #75
Sentry's Avatar
Ok, package hasn't come in yet. While I'm waiting though, I did rewire the injector harness.
By the way kids, don't be in a rush like I was and lay a soldering iron that's operating at 800 degrees fahrenheit on a bed sheet. It will burn **** up, as the last pic shows.
