Stage 3 Comp Cams....Anyone done it???
Old 02-22-2010, 06:22 AM
  #226
huckernage's Avatar
widedand is always good to have
your sensor has to be cut from your stock cam and press in in your new cam. you have to be precise more than a sniper
Old 02-22-2010, 12:18 PM
  #227
xxxxsh4d0wxxxx's Avatar
I think I am going to get the AEM wideband.
As for the cam sensor, I'm sure a race-shop would be able to do it.
Old 02-22-2010, 06:45 PM
  #228
huckernage's Avatar
do you know one.
innovate does good wideband too.
Old 02-22-2010, 07:53 PM
  #229
NWAE Cobalt's Avatar
talk to vince, he said at one point that he should be able to tune it out...not sure about it though...
Old 02-22-2010, 08:00 PM
  #230
huckernage's Avatar
vince has tuned one. but i told me that he has cam sensor correlation trouble
i already ask him if he was able to delete that sensor:
TFT dit (17:05) :
i am not totally sure about this
there was one 2007 2.2 we did stage cams on
he needs someone to try it and look like you gonna be guinea-pig.
but i m sure you wont try hit for the R&D of the 07+
Old 02-23-2010, 12:55 AM
  #231
That would be sick.
I'm going to stay away from the wideband. He just data logs everything anyway. All a wideband is, is a light-show, for us anyway.
Waste of $200.
Old 02-23-2010, 01:58 AM
  #232
more or less, it can still clue you into problems
narrow band is nothing but a light show
Old 02-23-2010, 02:33 AM
  #233
Yeah, I just don't foresee a problem with N/A, there is really no way you can lean out or anything bad unless you got a **** tune.. Or if you tune yourself, I'd get one then. It mostly happens with boosted cars, where they worry about being lean.
You know what I mean..? It's not like everything is fine then OOPS, running lean.. Doesn't really work like that.
Old 02-23-2010, 02:35 PM
  #234
Just a little FYI.. Here is what Vince from Trifecta thinks of the whole 4-2-1 vs 4-1 thing.
"If you’re asking my opinion as a professional tuner, I’d recommend the 4-2-1 for street use. You will have broader power gains across the RPM range which is more usable on the street. You don’t spend all day at 5000RPM or above unless you are racing it on a track."
Old 02-23-2010, 03:27 PM
  #235
I do
for the cam, since your pwer band is already so high it makes sense to have the 4-1 (esp if you rev out all the time freeway use and ****) but for mostly street use on the non cammed 4-2-1 makes sense...give you the power more where you will most use it
Old 02-23-2010, 06:18 PM
  #236
huckernage's Avatar
1. its true but when you need you will have. i prefere less usable on the street but when a honshit wants try me = bye my chummy
2. that me i need a 4-1
Old 02-24-2010, 12:36 AM
  #237
I do
See below.
That's exactly what I think. I'd rather have it up top where I need it. The HP/TQ is there with the 4-1, it just builds slower, and doesn't peak at 5k like the 4-2-1.
I understand the whole "more power where you use it most" thing, but when you need that up top power, remember that you traded it for your low-end/mid-range.
Plus the 2.4 intake manifold and 2.4 TB bump up your power-band also. I can see how it makes sense to get the 4-2-1 because you have so much high-end already, but at the same time it doesn't make sense.
Old 02-24-2010, 01:50 AM
  #238
See below.
that would work, except the 4-2-1 actually gives you LESS up top then nothing haha
Old 02-24-2010, 12:00 PM
  #239
I don't get what ya mean?
Anyway, I got some dynos from Trifecta of a bone stock Solstice with Clear Image's 4-2-1 vs 4-1, and to my view, the 4-1 beats the 4-2-1. Even down low and mid range.
http://www.trifectaperformance.com/t...derComparo.pdf
Old 02-24-2010, 08:04 PM
  #240
huckernage's Avatar
a solstice lost hp and tq due to his drive shaft.
number should be better with a traction car than a rear end drive
@tom
did you dyno on that on?
Old 02-25-2010, 12:22 AM
  #241
Either way, the 4-1 still beats the 4-2-1. Cams or not.
Old 02-25-2010, 06:38 AM
  #242
huckernage's Avatar
yes you are right
Old 02-25-2010, 12:41 PM
  #243
Hucker, may I ask how you fit drag bags with a strut in the way? I don't see why you would put them in the back.. Lol.
Old 02-25-2010, 05:37 PM
  #244
you use them so you dont get "squat" where when you launch your back end drops, transfering weight from the front, and causing less traction and tire spin off the line, they go in the back, inside the springs to do this, not up front. struts arent in the way
Old 02-25-2010, 07:05 PM
  #245
huckernage's Avatar
totally a failure in my case
this wilson is just good to be back to walmart
may be it was the quality od this wilson
60psi is to much according to mr wilson
Old 02-26-2010, 01:57 AM
  #246
Makes sense. I knew they didn't go in the front, strut is obviously in the way.. I just didn't think it would help that much in the rear.
HAHA! NICE!
Old 02-26-2010, 08:24 AM
  #247
huckernage's Avatar
my 14,2 was done w/o my dragbag
only pro-kit in front and stock coil in rear
it look like to :
Old 02-27-2010, 12:52 PM
  #248
mine looked like a cat in heat
Old 02-27-2010, 01:20 PM
  #249
huckernage's Avatar
inthis case
mine looked like a cat on attack mod.
yours is to passive cat lol miaouuuuuuuuuuuuuhhhhhhhhhhh
Old 02-27-2010, 01:22 PM
  #250
inthis case
at least mine isnt tupperwear
Quick Reply: Stage 3 Comp Cams....Anyone done it???
