Stage 3 Comp Cams....Anyone done it???
Old 01-30-2010, 01:56 PM
  #101
06_ion2's Avatar
not bad.
Old 01-30-2010, 02:58 PM
  #102
NWAE Cobalt's Avatar
Originally Posted by 06_ion2
not bad.
ty, yours is pretty impressive itself
Originally Posted by Maven
Um, youre gonna need your 2.4 TB and a 2.4 manifold, even though you should really get something better manifold wise if you truly want to take advantage of those cams, you should really get port work or consider buying somebodies already built/ported LSJ head, you MUST get valvesprings, you need to get neutral shafts or some variation of a balance shaft delete, you need a nice long tube 4-2-1 header, higher compression pistons would be really nice, not crazy high but 11:1 would make a difference.
ya...i just installed my valve springs, we shall see what this changes timing it this weekend with the stg2 cam :P
Old 01-30-2010, 03:29 PM
  #103
06_ion2's Avatar
Thanks but the procharger is going up forsale and its going turbo very soon.
Old 01-30-2010, 04:41 PM
  #104
nice! why not both?? :P
Old 01-30-2010, 08:13 PM
  #105
xxxxsh4d0wxxxx's Avatar
well i suppose you dont, but its going to be easier then having a seperat dp made...cause its a mid-longtube header
the cobalt community is cheap, 50$ is alot to most
and yes. more people street the car and want the power low and some high, as where people looking for the highest numbers/ best racing perf would sac a lil where you wont use it racing for where you will...aka most want it spread out as where fewer want more up top and sac down low.
look at hatrikstu (sp?) - he has the 4-2-1 and is putting down some AWESOME track times
i have the 4-2-1 and am putting down the highest WHP for N/A 2.2
i dont have a current dyno, as the last time i dynod the afr needed fixing and it was pulling ~20whp from me in timing....but..
with cia 4-2-1 header, 2.5" catless cia dp, 3" cia exhaust, cai, mrz alt & crank pullies, 2.4 tb, 2.4 intake mani, a shaved cyl head (.020" taken off), stage 2 cams and a bunch of supporting mods, i put down 180.16whp & 164.91 wtq
once the tuning was finished i carried the power all the way to redline, but i have not been dynod (car is down right now till timed...added 78lb valve springs)
So the 4-2-1 will not fall flat up high?.. I just figured with a tune you'd pick up bottom end lost with the 4-1, but what do I know. <-- Not sarcasm. So I'll put down higher numbers with the 4-2-1?
Side note: Isn't a 3" cat-back a bit big?
Thank you for all your information so far, you've been really helpful!
Old 01-30-2010, 08:18 PM
  #106
honestly i have not run their 4-1 on this setup, so i couldnt tell ya comparitivly, but i know that the smoother the gasses merge (way better with 4-2-1) the faster they will escape
and the 3" gets the proper pressures from the 2.5" dp and 2.5" muffler, the 3" is for future expansion and sound
Old 01-30-2010, 08:23 PM
  #107
Cool.. And it is all stainless steel right?
Also, why catless?
Old 01-30-2010, 08:25 PM
  #108
Also, why catless?
mine isnt stainless, i didnt want to spend the extra cash...not really a show car
i went catless cause i wanted LOUD in your face hahaha, and it was cheaper at the time
cause i got their exhaust custom fit to an existing muffler i paid a pretty penny for install at their shop
Old 01-30-2010, 08:43 PM
  #109
Yeah, apparently catless won't provide much of a gain at all over a high-flow.
I don't even think they offer the 4-2-1 in stainless.. I know they do for the 4-1 though, and it's like $550 for the header alone.. But I'm getting ceramic coated so it shouldn't rust.
Old 01-30-2010, 08:47 PM
  #110
thats a good option! and your right, not much of a noticable gain between none and highflow
Old 01-30-2010, 08:50 PM
  #111
I'm totally down for catless.. But I don't want to have my exhaust sound like poopy.
I can't believe a stainless header is $250 more than mild steel. Ouch. Only $70 for a stainless DP though, so I'll be doing that.
Old 01-30-2010, 08:51 PM
  #112
sweet deal.
its so much more cause the cost of the materials.
ill link you to some vids later of my car..i have to do the whole work thing...
Old 01-30-2010, 08:53 PM
  #113
sweet deal.
Is the exhaust sound that different? Like no bullshit?
Old 01-30-2010, 08:55 PM
  #114
HELL YES
i cant link now, but go look up user trh9490 on youtube, those are all my car
Old 01-30-2010, 08:58 PM
  #115
Dude, that's you..? Didn't you have a different user name on here? Anyway, that **** is ******* LOUD. I don't know if I could deal with such.
Old 01-30-2010, 09:25 PM
  #116
it is pretty loud, but we have a nice dodge durango for going on long trips, so this is my local commuter and just for fun
Old 01-30-2010, 09:36 PM
  #117
What are your views on the LSJ injectors on a bolted and tuned L61?
Also, the 2.4TB is the best option for a TB right?.. Like the LSJ doesn't fit right?
Old 01-31-2010, 02:44 AM
  #118
for anything but boost the 2.4 is best (until you go crazy haha)
as for injectors i was about at the top of the range of stockers, but i would have been OK using them...although since im not done it was a good idea
Old 01-31-2010, 02:59 AM
  #119
06_ion2's Avatar
Yes if I were to start over id sell my car and buy a 2.4 auto and put on a zzp turbo kit.
Old 01-31-2010, 03:06 AM
  #120
that would be pretty sweet
if i knew i would be doing what i am with the car, i would have held out in the beginning for more
but im working with what i have
Old 01-31-2010, 12:50 PM
  #121
My build in a few months will be done.. Until I decide if I want cams, or whatever else.
ARK GRiP cat-back (2.6" piping), 2.4 TB, 2.4 intake manifold, CAI 4-2-1 header/dp with high flow cat, Injen CAI, Trifecta tune.
Should lay down decent numbers for only bolt-ons.
Old 01-31-2010, 03:06 PM
  #122
06_ion2's Avatar
Go with stage 2 cams and a ported head with valves and springs.
Old 02-01-2010, 01:00 AM
  #123
ARK GRiP cat-back (2.6" piping), 2.4L, 2.4 intake manifold, CAI 4-2-1 header/dp with high flow cat, Injen CAI, Trifecta tune.
shouldnt be too bad at all!
eventually my head will get ported and such...if i can score a cheap second head itll come faster
Old 02-01-2010, 02:22 PM
  #124
I need to find the right TB for my 2008..
Isn't it a different pin or something for 2008?
Old 02-01-2010, 03:07 PM
  #125
huckernage's Avatar
6 pins instead of 8 pins
Quick Reply: Stage 3 Comp Cams....Anyone done it???
