SUPERcharged!
Old Dec 31, 2009 | 01:16 AM
erock666's Avatar
SUPERcharged!
i have the older 05 cobalt engine mount i just ordered the 06 engine mount and adapter to install on my car witch will be here on Monday but i have an issue still when i started it up it ran and stalled , the tensioners pushed against the the motor mount , it need to go about a 2/16 of a inch inward still , it does rub pretty good (only started the car twice so i didnt ruin anything) would this casue the engine to be under more load at idle and stall out ? casue the car revs and moves fine ( tensioners not touching under load) , just under idle it stalls . like i sayed i got the new engine mount coming and the car will sit till i get the mount in . but i wanna now if this would cause that
Old Dec 31, 2009 | 07:38 AM
HunterKiller89's Avatar
tnesioner shouldnt still be rubbing. Mine didnt even need to be ground, but the clearance is stupidly close (im sure it rubbed under a little engine movement). In fact, it shouldnt rub on the mount at all...you mean its rubbing on the engine block?
post up a pic
edit: if your issue is like below, then do as suggested and just grind some more.
if its rubbing against the motor mount though like you stated, then you've got issues
Old Dec 31, 2009 | 09:01 AM
Mr.N00bLaR's Avatar
https://www.cobaltss.net/forums/show...155214&page=15
I think most people do some grinding because of the clearance -- 13th picture I think.
Installed on mp81's car:
https://www.cobaltss.net/forums/show...&postcount=264
Old Dec 31, 2009 | 10:35 AM
ml2242's Avatar
i had to grind the block quite a bit to be rid of the rubbing on my tensioner
Old Dec 31, 2009 | 10:48 AM
stenguyen1's Avatar
yea i had to do it also if you look at my build thread it shows that i had to grind mine down also
Old Dec 31, 2009 | 05:53 PM
erock666's Avatar
ok i have the old 05 engine mount i had to order a new engine mount witch comes monday , i grinded the engine mount down so it wouldnt rub but it still touching (not the engine). but i got some surging on frist start up then the second it ran fine but the tensoiner rubbing on the engine mount stalled my car unless i gave it gas .
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
medic710
Sep 6, 2015 08:53 PM
