thermostat issues
Old Feb 19, 2013 | 11:58 AM
cisco123's Avatar
thermostat issues
Thermostat keeps turning off and on does anyone know what would be the source of the problem
and i did install a new one
Old Feb 19, 2013 | 12:05 PM
steveobed's Avatar
maybe something with the cts
Old Feb 19, 2013 | 12:15 PM
cisco123's Avatar
Don't know if it matters but it is supercharged
Old Feb 19, 2013 | 12:18 PM
steveobed's Avatar
wouldn't matter but I'm not entirely sure if the cts and thermostat work together
Old Feb 19, 2013 | 12:20 PM
cisco123's Avatar
Ok thanks ill look into that
Old Feb 19, 2013 | 12:25 PM
steveobed's Avatar
I tried looking it up just now and I couldn't really find anything, the t stat is more of a mechanical part so it may not but I can't think of anything else that would cause that
Old Feb 19, 2013 | 12:27 PM
steveobed's Avatar
yeah they do work together, I would look into trying to clean the cts maybe or just replacing it
Old Feb 19, 2013 | 01:06 PM
cisco123's Avatar
What is the cts so i can get the part
Old Feb 19, 2013 | 01:10 PM
Big Mills's Avatar
I think CTS = Coolant Temp Sensor
Old Feb 19, 2013 | 01:14 PM
cisco123's Avatar
Ok thanks
Old Feb 24, 2013 | 05:15 PM
cisco123's Avatar
Ok just installed new cts in car been running about 15 min coolant won't come on still showing ---f
Old Feb 26, 2013 | 05:26 PM
hommie2003g's Avatar
i had the same problem for a year till i finally fixed it. the seal on the thermostat went bad. replace your thermostat and you will be good to go. its not the sensor. if you want to check if its the sensor, disconnect the ecu under the hood in front of the fuse box, both connections, for 30 sec then plug it back in. when you turn the car back on your sensor should work again.
Old Feb 28, 2013 | 02:54 AM
scagnetti76's Avatar
Not sure how unplugging the ecu will check a thermistor...
Thermostat and CTS do work together, but not directly. The ecu uses logic based on ambient air temp on start up, engine temp, vehicle speed and load over time among other inputs to code for a bad t-stat. But if you have no t-stat code, p0146 IIRC, installed the new t- stat and ECT correctly(t- stat in the propper direction... not trying to be an ass) my GUESS would be something to do with the sc build. How recent has the sc build been done, any DTC's at all? If not, I would have it scanned to see which monitors have or have not run and post back.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
