These Cams
Old Apr 29, 2008 | 11:25 AM
Cobaltkid69's Avatar
These Cams
Im Modin my 2.2 in my 05 cobalt and have picked up a few things...
what i am wondering is are these cams gonna be ok in a n/a set up?
Comp Cams 113200 Xtreme Energy Ecotec XE252HR-11 Camshaft Set - Stage 2
The COMP Cams® ECOTEC camshafts provide increased horsepower and all around performance for this increasingly popular sport compact application, without compromising engine durability. Using Spintron® developed ECOTEC lobe profiles, the COMP Cams® engineering team optimized intake and exhaust flow to deliver dramatic performance improvements. This was accomplished by opening the intake valves faster with aggressive “fast ramp” lobe designs. The results are improved throttle response and “seat of the pants” performance. The new COMP camshafts also utilize quicker valve closings, giving the ECOTEC engine a much broader power band.
VALVE LIFT: .423 Intake & .419 Exhaust
DURATION (Advertised/@.050"): 252/256 Intake & 210/212 Exhaust
LOBE SEP. ANGLE: 111°
RPM OPERATING RANGE: 2600-6800RPM
CAM GRIND #: XE252HR-11
APPLICATION: Hydraulic Roller for Street Applications, wide power range, strong torque, works best with programmer or custom computer programming.
not gonna turbo it for awhile just want to add hella n/a hp!?
Old Apr 29, 2008 | 11:26 AM
MadBrad's Avatar
going to need a tune with stage 2
Old Apr 29, 2008 | 11:56 AM
how much tuning?
which stage is doable without tuning?
Last edited by Cobaltkid69; Apr 29, 2008 at 11:56 AM. Reason: Automerged Doublepost
Old Apr 29, 2008 | 12:06 PM
IonNinja's Avatar
where did Gravana get all these other cam profiles from? i noticed those the other day too
to get the most out of the cams and maintain drivability, you'll want tuning with any cams. however you could probably get away with no tuning on stage 1 comp cams
Old Apr 29, 2008 | 07:12 PM
BlackLS's Avatar
So with a tune what kind of numbers could you expect from Stage 1 cams and what kind of numbers from Stage 2 cams
Old Apr 29, 2008 | 08:04 PM
Sloco Productions's Avatar
its gay with 07 they put a cam position sensor on the stock cam....aftermarket dont work....i bought sum a while back and called up comp cams and was told id have to send em back and theres nuthing they could do...
Old Apr 29, 2008 | 09:33 PM
Mike85220's Avatar
Wow, that is gay!
Old Apr 29, 2008 | 10:05 PM
TurboTechRacing's Avatar
We are Comp Cams #1 dealer for the Ecotec. Stage 1 works fine without any tuning. A custom tune should be used with the stage 2. Stage 3 is VERY wild and should only be used by those upgrading to the Ferrea valve train, and have the option for dyno time and a custom tune.
PM us with questions.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
