throttle body grounding mod
Old Aug 8, 2008 | 12:41 AM
pickin my brother up's Avatar
has anyone tried this yet? i have a friend with a mazda3 and lancer and did this mod to both of them. unfortunately its much easier to do if the battery isnt in the trunk, but im thinking maybe you can get the same effect using the jumper short cut battery under our hood.
Old Aug 8, 2008 | 12:56 AM
HackAbuse's Avatar
I thought you were ******* crazy when you said this, but I actually looked it up and it seems pretty feasible. I might actually try it just for ****'s n giggles.
http://www.msprotege.com/forum/showt...hp?t=123631517
Old Aug 8, 2008 | 12:58 AM
Herndon_High_SS's Avatar
Interesting. I dont know what to say, cool if it acutally works or "**** i'm so stupid what was i thinking?"
Old Aug 8, 2008 | 12:59 AM
really cheap too. i dont know what to expect for it on a 2.2, but if it works....hell
Old Aug 8, 2008 | 01:04 AM
HackAbuse's Avatar
Maybe if I have time tomorrow I'll throw a wire on there and see if it makes any difference.
Old Aug 8, 2008 | 01:06 AM
cblt12's Avatar
i dont see how this could do anything, with my bit of electrical knowledge.
just ground it to the body or somthing, its the same exact thing dont waste the wire goin all the way to the trunk
Codyak Supercharged's Avatar
wtf man lol
i dont see how this does a damn thing. The T.b is already grounded through the engine grounds anyway...sooo...?
Old Aug 8, 2008 | 01:09 AM
HackAbuse's Avatar
Of course, lol
I'll probably either ground it at the engine block, or ground it where my nitrous solenoids are at.
Originally Posted by Codyak Supercharged
wtf man lol
The TB is grounded with a 16+ gauge wire, the point is to give it a larger ground
Old Aug 8, 2008 | 01:11 AM
ItalianJoe1's Avatar
I'm with this guy.
Old Aug 8, 2008 | 01:13 AM
impulseballer's Avatar
quoted from mazda site.
"All it does is decrease the throttle tip-in delay, provide a more linear acceleration give you smoother shifts."
definitely something that's worth a try.
but yeah it would be a bitch bringing that wire all the way to the trunk.
Last edited by impulseballer; Aug 8, 2008 at 01:14 AM. Reason: Automerged Doublepost
Old Aug 8, 2008 | 01:18 AM
If anyone wanted, test it by doing immediate before-after, just disconnect the ground at the TB, try the car, then connect it and try it, see what you feel.
Also, I imagine it would do more on the 2.2/2.4, the SS/SC goes onto an all metal setup, there isn't a giant plastic manifold to insulate it. LSJ's are probably better grounded already. I might have to break out the OHM tester.
Last edited by ItalianJoe1; Aug 8, 2008 at 01:18 AM. Reason: Automerged Doublepost
Old Aug 8, 2008 | 01:21 AM
i think that would be the best way to test it...maybe ohm meter lol?
Old Aug 8, 2008 | 01:22 AM
HackAbuse's Avatar
I have a multimeter I could test it with
Old Aug 8, 2008 | 01:24 AM
Same ****. Just compare your car to an SS/SC, from say the head to the TB. Your car should be open, SS/SC should be nice and low.
Then check for ground from the TB to the frame or something, same spot on both cars. Should be the same result from what I can think of.
Old Aug 8, 2008 | 01:38 AM
HackAbuse's Avatar
Kay, I'll do the TB to the head, then from the TB to the Driver side strut tower bolt
First I'll do OHMs with the car off, then with the car running, then while the car is idling, I'll check voltage to see if there is any static charge at idle.
BRB with results.
Old Aug 8, 2008 | 01:45 AM
Of course, lol
Any static build up would be transfered to the block which is grounded. The resistance is there but the electric value isn't there. IMO of course.
on a side note i have had to ground monitors in cars because of the electric current they pickup through the other equipment, and shows up in the screen as waves. But thats not a static build issue...
hell try it would be interesting to see what happens. Although the basis of this theory is static effecting a servo...
Old Aug 8, 2008 | 01:47 AM
HackAbuse's Avatar
Okay, this is interesting.
The casing of the throttlebody is not grounded at all.
I triple checked this.
And heres another weird but interesting thing, i checked the voltage difference from the throttlebody to the chassis in four different places and came up with a 0.3v (+/- .05v) difference in voltage
Old Aug 8, 2008 | 02:23 AM
I wish I knew more about grounding and everything so i dont know what that means...does that mean there is potential benifits to grounding the throttle body?
Old Aug 8, 2008 | 02:26 AM
HackAbuse's Avatar
The supercharged models are already grounded because the intake manifold is metal
Old Aug 8, 2008 | 02:29 AM
So how about the 2.2 and 2.4's plastic ones? They might benifit with this if it actually works.
Old Aug 8, 2008 | 02:37 AM
bridfi's Avatar
hmmmmm subscribed
Old Aug 8, 2008 | 02:41 AM
tonio5555's Avatar
This is interesting hmmm...
Old Aug 8, 2008 | 02:44 AM
Spanky's Monkey's Avatar
this does seem promising.
Old Aug 8, 2008 | 02:45 AM
Mr.N00bLaR's Avatar
Hack, this work or not? ..lol.
Old Aug 8, 2008 | 02:49 AM
HyphyDrivah's Avatar
Haha! Were all waiting...
Subscribed too!
