Tom's Build :D
#331
just worked a deal for a water temp gauge, volt gauge, a triple pillar, a narrow band (will be borrowing a wideband at first to make sure we are in spec ) and am installing them in a few weeks. will be getting an oil pressure gauge soon as well
i have an idea of 2 custom mounting places...ill reveal eventually
brakes i want are about 215$ for the rotors, 100$ for the brake lines, and 80$ for pads...but they will be AWESOME!!!!! those are to come when i have more money
#332
just went to the track again (twice in two weeks)
so far 14.951...puts me in first on the site
not the run, but one of them against a stock 2.2
http://www.youtube.com/watch?v=W5GerxQOSXE
#335
first run of the night i was having issues getting it into 4th, so i wasnt trying to brake anything
the run that i clocked in at 14.95 was alot faster...it helps that on that run i was power shifting lol
#338
with your cams.. the right size tires you should have a 7200 rev limiter or so and be able to keep it in 3rd
#339
... are you running smaller then stock tires? and whats your rev... if your tires are smaller .. get the right sized tires.. I had that issue too .. i ran my snow tires at the track.. and i was trapping 96 or so .. and had to shift into third..
my tires are less then 1/2 in total diameter smaller from stock
and the cams have nothing to do with being able to stay in the same gear longer... ?:/?
#342
and with stock 2.2 i trapped 89.89mph stock tune 6.5K rev limiter in 3rd gear with stock tires
im lookin to rev out to 7.5K n still be in third for trap... and spray ill see 4th lol
YOU NEED TO REDYNO once you get some cash saved up lol
#343
get your 60s down :P
thats what i need to do. what are the least busy days at paciffic? i wanna get more than 3 or 4 runs in. the one time i went to bremerton i got 11 runs in and i left 2 hours before the track closed
#344
well cams can produce the higher rpm power so you will want to not shift until some hundred rpms above stock.
not to mention higher 60's will make for higher traps..
#345
well when i get new tires and get them closer to stock size...then yes lol, until then i have to shift into 4th lol
also, i believe you mean lower 60's mean higher traps lol
