Tom's Build :D
Old 05-01-2009, 01:18 PM
  #326
06_ion2's Avatar
a rear disc setup is being fabed up wont be long before they can make them..
Old 05-01-2009, 01:24 PM
  #327
Jn2
Jn2's Avatar
Originally Posted by NWAE Cobalt
nice, i dont ahve the money for somethign like that
i dont have the money eitherh brake upgrade is something i'll do when i cant think of anything else to mod
Old 05-01-2009, 01:51 PM
  #328
NWAE Cobalt's Avatar
im doing it cause i can WAYYYYY outdrive the stock brakes that have 50k on them lol
Old 05-01-2009, 02:15 PM
  #329
stenguyen1's Avatar
hey if you want some great and cheap rotors. let me know. i got mine for 97 bucks.
Old 05-01-2009, 03:56 PM
  #330
nice!, although i have to ship mine from the uk for what i want to do
Old 05-02-2009, 01:23 AM
  #331
just worked a deal for a water temp gauge, volt gauge, a triple pillar, a narrow band (will be borrowing a wideband at first to make sure we are in spec ) and am installing them in a few weeks. will be getting an oil pressure gauge soon as well
i have an idea of 2 custom mounting places...ill reveal eventually
brakes i want are about 215$ for the rotors, 100$ for the brake lines, and 80$ for pads...but they will be AWESOME!!!!! those are to come when i have more money
Old 05-16-2009, 02:40 AM
  #332
just went to the track again (twice in two weeks)
so far 14.951...puts me in first on the site
not the run, but one of them against a stock 2.2
http://www.youtube.com/watch?v=W5GerxQOSXE
Old 05-16-2009, 04:55 AM
  #333
Jn2
Jn2's Avatar
Good times there, some slicks and u could be deep into lsj territory....don't forget to bring a flamesuit and some bitch b gone spray when u arrive there :p
Old 05-16-2009, 09:12 AM
  #334
elecblue06's Avatar
woowwwwww... idk if it's possible for you to shift any slower over there grandma
still not seeing how you'd keep up with an lsj but i'll need to see some slips too see how clean that run was...
good times none the less.. broke into the 14's sooner then i did
Old 05-16-2009, 10:29 AM
  #335
first run of the night i was having issues getting it into 4th, so i wasnt trying to brake anything
the run that i clocked in at 14.95 was alot faster...it helps that on that run i was power shifting lol
Old 05-16-2009, 11:33 AM
  #336
elecblue06's Avatar
umm whats your rev limiter and why were you shifting into 4th oh nm you're running smaller then stock tires right?
Old 05-16-2009, 12:03 PM
  #337
car tops 3rd at just under 90mph...about 87mph i think (7k limiter) and i trap at about 95(ish) so i have to shift into 4th
Old 05-16-2009, 12:08 PM
  #338
elecblue06's Avatar
... are you running smaller then stock tires? and whats your rev... if your tires are smaller .. get the right sized tires.. I had that issue too .. i ran my snow tires at the track.. and i was trapping 96 or so .. and had to shift into third..
with your cams.. the right size tires you should have a 7200 rev limiter or so and be able to keep it in 3rd
Old 05-16-2009, 12:12 PM
  #339
unless i get grossly oversized tires i wont be able to keep it in third lol
my tires are less then 1/2 in total diameter smaller from stock
and the cams have nothing to do with being able to stay in the same gear longer... ?:/?
Old 05-16-2009, 02:14 PM
  #340
Spectral's Avatar
60 ft times and trap you bastard haha i texted you and post on nwm asking now im here asking hahaha
Old 05-16-2009, 02:30 PM
  #341
i reposted there lol
60' is 2.3 trap is 94mph
Old 05-16-2009, 02:56 PM
  #342
o3nisoaso3's Avatar
well cams can produce the higher rpm power so you will want to not shift until some hundred rpms above stock.
and with stock 2.2 i trapped 89.89mph stock tune 6.5K rev limiter in 3rd gear with stock tires
im lookin to rev out to 7.5K n still be in third for trap... and spray ill see 4th lol
YOU NEED TO REDYNO once you get some cash saved up lol
Old 05-16-2009, 03:37 PM
  #343
Spectral's Avatar
get your 60s down :P
thats what i need to do. what are the least busy days at paciffic? i wanna get more than 3 or 4 runs in. the one time i went to bremerton i got 11 runs in and i left 2 hours before the track closed
Old 05-17-2009, 01:22 AM
  #344
elecblue06's Avatar
exactly... your cams produce power to about 7500 if i remember correctly so extending your redline to 7200 will be in your benefit as you'll shift into your powerband.. any difference in tire size will make a difference .. a 7k redline should be able to get you to hit 94 mph in 3rd with stock tires... i've done it
not to mention higher 60's will make for higher traps..
Old 05-17-2009, 03:35 PM
  #345
well when i get new tires and get them closer to stock size...then yes lol, until then i have to shift into 4th lol
also, i believe you mean lower 60's mean higher traps lol
Old 05-17-2009, 05:35 PM
  #346
o3nisoaso3's Avatar
my motor is fully built, i told Vince i wanted rev limiter gone, so i could rev to 8192, and he still put it at 6900....???
Old 05-17-2009, 06:34 PM
  #347
i believe we put mine at 7200
Old 05-17-2009, 11:38 PM
  #348
bikeboyben14's Avatar
tom i got springs and cam swap tool combo 300 shipped lol
Old 05-17-2009, 11:44 PM
  #349
lol, i know haha. im not doing any more engine work till i build a new engine...then i wont need the tool :P
Old 05-18-2009, 12:33 AM
  #350
elecblue06's Avatar
no... higher 60s mean you're spinnign .. spinning means you're going to pick up more speed.. so i meant exactly what i said ..
Quick Reply: Tom's Build :D
