Tom's Build :D
Tom's Build *updated*
ok, so everyone else is....MY TURN!!!! lolol
so, my car as it sits has (performance wise):
clear image 4-2-1 header
clear image 2.5" catless DP
clear image 3" exhaust w/ magnaflow resonator and muffler
ebay CAI w/ aem dryflow air filter
Trifecta tune
upper strut bar
TTR rear sway bar
ss/tc struts and shocks
H&R sport springs
17" rims w/ Nitto Neogen 225/45/17 tires
TTR solid upper engine mount
TTR tranny mounts
MRZ lightweight alternator pulley
MRZ lightweight crank pulley (oem size due to stereo)
2.4l intake mani
2.4l TB
lsj injectors
stage 2 comp cams
Shaved cyl head .020"
Im planning on (in the near future):
eibach front sway bar
upgraded end links
11" front brakes: EBC rotors w/ hawk ceramic pads
drag radials
wider lighter rims
some other odds and ends :P
after this (cause ill be happy for a while) im going to build a second motor:
not sure on details but...
rods, pistons, ported and polished head (bought with all upgraded parts installed...not sure of vendor on here, but there is one), thinner head gasket, clutch, lsd tranny, balance shaft deletesaxels, upgraded clear image 4-2-1 header, and another retune lol.
im hoping to hit mid 200's whp wise with this and think that its very possible if i can get the compression ratio up there a bit.
Right now (before the tranny and engine mounts and on stock tires with the old exhaust) i ran at 154.7 whp and 157wtq and a 15.4s at the track.
i think with some practice as it sits i can hit damn close to an even 15s 1/4 time and close to 160whp now that i have upgraded the exhaust.
Will update as i add parts and do some track/ dyno runs
thread updated with build info, pics, dynos, track runs, etc
Trifecta tune
upper strut bar
TTR rear sway bar
H&R sport springs
TTR tranny mounts
2.4l intake mani
2.4l TB
lsj injectors
stage 2 comp cams
upgraded end links
drag radials
wider lighter rims
i have an extra 2.2 intake mani i send you too if needed and the stock other stuff off the car
someone else and i are talking...he is trying to get an ss and trade his ls...he has the 2.4 tb, intake mani, and stage 2 cams....so he offered me a good deal if i buy all three....
just waiting for him to get the new car and to pass it by teh girly
looks like as long as everything goes to plan i may be getting a 2.4l intake mani, tb, and stg 2 cams....and need to talk to someone about injectors...but should have all this very soon hopefully
