Tom's Build :D
Thats what i wa going to do but i said no i'd rather have an SS/SC. Plus then I'd be able to use HPTuners, and all the other cool stuff it comes with. I'm packing the cams and intake mani in a box then going to weight them for ya.
i have thought about that....if i do build the **** outa the engine like i want, i then have the capabiity of running n2o if i want....maybe lol,,,dont know if i want to though after spending that much money on the build...
Last edited by NWAE Cobalt; Feb 23, 2009 at 04:51 PM. Reason: Automerged Doublepost
Don't mean to bash on your plan, but man it's hard and expensive trying to build a fast NA 4 cylinder.
If you spend that much money on this build, I'm going to slap you in general. You could sell your car, take what you were going to spend and buy a used gto or even pick up a foxbody mustang for twice the power NA.
both, i figure since the s/c is rated at 205 whp and i hope to be pushing 180+ that it couldnt hurt to put them on now and have them for when i get to a higher hp in my build
hey tom have you considered rasing the compression ratio to make use of your choosen cam? i started researching the NA build and found that you can indeed build a 200+hp NA build but it's gonna require raising the cr and running high octane fuel possibly even race gas depending on your power goals. keep in mind raising the cr is gonna involve buying more then just pistons and rods and if you want to make safe power at those compression levels you may want to bore the block out to a 2.5l.
just my shitty 2cent
yea get high compression pistons like 10.5:1, and port and polish the head and build the motor you should reach more than 200hp
You will be fine with your stock injectors
1 was looking at 11:1 or even 12:1 for 250hp plus a 100 shot on race fuel. the redline would have been set at 8k and i was gonna build for the track but still run as a "dd". too much tuning downtime for my taste. it would be impressive to build a high horse power L61 NA but it's not in the cards for me. for now i'm thinking of dropping the zzp turbo kit without the intercooler and using my buddys stock evo 9 mr fmic and welding up some custom piping for it.
im going to get it bored, shave the head down, new pistons and rods, and a thinner head gasket...
dont know the exact details yet...but thats a little ways down the road
Last edited by NWAE Cobalt; Feb 24, 2009 at 07:36 PM. Reason: Automerged Doublepost
so pretty soon the debate will be over...i should be getting the taxes in the next two days, ill buy the cams, mani, tb, and injectors and after it all gets here get it installed and dyno tuned by vince...then i can say for sure what im putting to the ground with it
next step after that is upgraded brakes and sway bars....then finish up with some appearance stuff
after that...its time to find a donor motor to strip down and start building
Well there will be a fully built, cammed 2.2L cobalt once he decides to put the motor back together. haha but the cams stop producing power at 7.5k so i don't see the point reving past that.
The key parts to rev that high is strong valvesprings, and the balance shafts
