Top Speed
See HACK there are 2.2 balts out there that for some reason can get into the 15's with little work. First off the newer the car, the better it will run. and for those who don't think so the 05 06 and 07 are all rated slightly differently in horse and tq. i believe it goes from 05-143hp 06-145hp and the 07 has 148hp. and not all cars are the same some even with exact mods one will be faster than the other. ill just have to let you know what my auto does when and if i get it to a track. id almost guarantee that it will do a 16.0-16.2 with my mods now.
weirdest case is that the speedo measure tire rotation, but even at that, a bigger tire/wheel assembly would still work around it. and i doubt it works like that.
only problem is, you dont actually know how fast you are going lol
to my furthest knowledge my friend, you are correct. the speedo doesnt really KNOW how fast you are going, it just calculates it using the engine speed and which gear you are in. well thats what i think? anyway if you get a bigger tire/wheel assembly my friends (since the stockers with the hubcaps are ****** PUNY, i hate them) then your tires will be covering more ground per rotation, but your speedo does not know that since the engine, transmission, and drivshaft are all rotating at the same speed as they would be with the smaller tires. so when it says your going 115, you could be going way over, depending on the size of the wheel.
im not talking about swapping the cluster. im talking about getting their vin number and uploading that pcm info into my pcm
You wont necessarily be going faster either cause i went from stock 15s to aftermarket 17s and i used my boosses gps to check how fast i was going and my speedo hit the fuel cutoff at 105 but the gps said i was only doing 103. There are also numerous tire size calculators that will let you know exactly how much faster or slower you will be after changing tires.
get what im sayin?
ill check what the ###/##/## are for his tire next time i see him, or if anyone with a stock SS N/A could post it that would be great
and it is a 2006
Last edited by NWAE Cobalt; Mar 6, 2008 at 06:03 PM. Reason: Automerged Doublepost
Elaborate, please? I work for a GM dealer, and own a 2007 1SS coupe. I haven't heard about this reflash though...anything more you can tell me would be appreciated
my BASE 2.2 can bury the 120 speedo and go way past it in 4th gear and still keep on going.....not all the cars will have the same limiter and some wont even have it.....like mine....and my ecu is untouched
