Topout?
Old Dec 17, 2007 | 03:17 PM
zerodead0's Avatar
Topout?
If The 2.2 Is Upgraded, Can It Go Past 120 Mph Cause My Car Doesnt Go Past 115, How Can I Change This
Old Dec 17, 2007 | 03:20 PM
Scythe_Snake's Avatar
Without changing your ECU, no. You'll just get their faster.
Old Dec 17, 2007 | 03:21 PM
HatedCobalt's Avatar
my 07 LT2 tops out at 123-127.
Old Dec 17, 2007 | 03:25 PM
chevysalesman614's Avatar
why would you want to? i used to sell them and i wouldnt feel safe going that fast in a car than feels as sloppy as the 2.2
you better do suspension work or we'll be reading about you dying while racing a moped or a stock 1990 crx
Old Dec 17, 2007 | 03:30 PM
njtrippe's Avatar
My 07 2LT has been past 120. Don't know how far past because I ran out of speedo at 120
Old Dec 17, 2007 | 03:31 PM
anthonyS88's Avatar
i would never drive that fast lol
Old Dec 17, 2007 | 03:33 PM
steddy2112's Avatar
That must take awhile to get to...
Old Dec 17, 2007 | 03:35 PM
anthonyS88's Avatar
i bet i can hit 120 real quick, but i dont plan on doing it
Old Dec 17, 2007 | 03:40 PM
redlineblueline's Avatar
Old Dec 17, 2007 | 03:41 PM
anthonyS88's Avatar
the cons outweigh the pros in driving excessively fast on a public road
Old Dec 17, 2007 | 04:57 PM
moes's Avatar
couldn't you just do a swap from your ls (i'm assuming you have, because thats what they top out at) and switch it to a lt ecu because its the same engine/transmission but the only difference is the ecu is set to 125 instead due to better tires that come on the lt.
Old Dec 17, 2007 | 05:02 PM
D4u2s0t's Avatar
not true at all. i had my 2.2 up to about 115-120 and it felt rock steady. i didn't feel unsafe at all. it did take a long time to get there though
Old Dec 17, 2007 | 07:18 PM
shawn672's Avatar
i can get to 100 pretty quick, after about 115 its a dog, but ive maxed out at 125 just like i should be able to: 3LT
honestly i drive about 80-85 to work everyday, ive had to rush sometimes and ive hit 100-110 quite a few times. 4 lane expressway with pretty fair roads and no traffic...ill take my chances
but the suspension on these things is so sloppy. i can turn my sterring wheel back and forth a good 10degrees each way and still go straight..eww
Old Dec 17, 2007 | 07:21 PM
HackAbuse's Avatar
winnah!
I had my LS Sport up to 128, laterally it's rock solid, but watch out for those bumps at that speed! When you're going that fast it doesn't take much to make you go airborne
Old Dec 17, 2007 | 07:43 PM
YSUsteven's Avatar
Don't we have speed sensitive steering in our cars?
Old Dec 17, 2007 | 07:50 PM
Preston's Avatar
I had my car up to 110..and decided to stop...i've never driven faster than 115..and that was in my rents Grand Am.
I dont like to go that fast alot..had a experience where a wind gust got under the car and the front end was turning and i was going straight..eeek.
Old Dec 17, 2007 | 07:59 PM
anthonyS88's Avatar
my ss went 140 on the dyno lol
Old Dec 18, 2007 | 08:57 AM
RedBaseBolt's Avatar
I've been up to 128 mph before aswell.
Old Dec 18, 2007 | 05:40 PM
ebristol's Avatar
Put on bigger tires. Fool your speedo into thinking you are going slower then you actually are.
Old Dec 18, 2007 | 05:42 PM
gre23a's Avatar
my 2007 3LT is limited to 110 mph
Old Dec 18, 2007 | 06:02 PM
novascotiag5's Avatar
with rims and tires the car felt fine at higher speeds on a closed track in a strait line. but when braking you can tell how bad the stock brakes are. After wheel and brake upgrades and suspention prolly too you could consider it cause it has the abilty to go as fast as you want to.
Old Dec 19, 2007 | 03:10 AM
shawn672's Avatar
no its not. if it is, the dealer messed with it, you might want to get it fixed and anything else they may have messed up
3LT, unless somehow u got it without the 'Sport Package' (chrome exhaust tip, 17' alum rims, diff gauge faces, etc)
Old Dec 19, 2007 | 03:31 AM
c0ld29's Avatar
Yeah, i think all rack and pinion steering is like that. The steering response changes with speed. Safer in my opinion
Old Dec 19, 2007 | 11:03 AM
blak2.2balt's Avatar
for a 06 2.2 is there any way to swap the computer from another 06 2.2 cobalt with a higher speed limit cause mine is set at 105 and im building a turbo kit and really dont want to go standalone just yet.
Old Dec 19, 2007 | 12:16 PM
Sw4y1313's Avatar
I will be testing the SMT-6's Road Speed governor option which allows you to go past the governor without the car knowing. But you really shouldnt be going faster then 105 on the street. And if your going turbo, your going to need a lot more then just a turbo kit to get higher then 105 trap speeds in the 1/4 mile. If i were you you should we worrying about a lot more things then the governor. Trust me...
