tranny swap
Old Sep 25, 2012 | 01:58 PM
SlobatLT's Avatar
tranny swap
Alright guys I know im gonna catch abunch of **** over this but I don't really care. I want to do it.
one of my good friends owns a shop (like a legit shop.lol not tire and lube) and if i cant get it done for free then it wont cost much money.
Im planning on pulling a tranny out of a low mileage cobalt this would be best because i could take it out and all the other parts i need, rather than ordering the parts and having to guess about all the little stuff.
If that doesnt work then ill just buy a new tranny.
I've heard abunch of stuff about mounting points and stuff like that and really i just need to know if there is anything special im going to have to get made or will it just bolt right up. i dont think this will be the case since everything is pushed forward on the auto.
any help will be appreciated. i want to know what problems im going to run into before i take on this project.
thanks guys.
Old Sep 25, 2012 | 02:15 PM
Hockeyman's Avatar
thanks guys.
um...wat?
Auto to manual I am guessing?
Old Sep 25, 2012 | 02:17 PM
PSHHH's Avatar
i was thinking gender change.
Old Sep 25, 2012 | 04:07 PM
bluebalt07's Avatar
You will need a trans, axles, trans mounts, engine mounts, wire harness, pcm, clutch, flywheel, pressure plate, tob, master cylinder, clutch pedal assembly. Trust me this isn't as easy as you think
Old Sep 25, 2012 | 09:48 PM
SlobatLT's Avatar
What axles will i need? im guessing since you said ill need engine mounts and trans mounts that the engine and new transmission will have new mounting points. if i were pulling this from another cobalt couldnt i just pull all that stuff out of it. if thats the case then it would seem the hardest thing would be remounting everything.
EDIT: What the hell is a "tob"
2nd EDIT: Also, if it all came from another 07 cobalt could i use that pcm?
Old Sep 25, 2012 | 09:54 PM
TommyTwinCams's Avatar
Auto to manual?
If so, it's a LOT of work, but I applaud someone going for it. Axles would be for a Getrag F23 transmission, Since that's the manual 2.2 and 2.4L Cobalts/Ions/HHR's/G5's came with. 2.0L's came with a Saab F35 that has proven somewhat problematic.
Old Sep 25, 2012 | 10:00 PM
Fitz88's Avatar
tob = throw out bearing
Old Sep 25, 2012 | 10:11 PM
BankerBalt's Avatar
Sell your car and buy a manual. It will be cheaper and more reliable
Old Sep 26, 2012 | 12:01 PM
SlobatLT's Avatar
I cant. I found a 08 stock black ss/tc with only 50,000 miles the price was 13,500
i could probably get close to ten out of my car, so i wouldnt owe much but i cant do it.
so this is the next best thing for me.
however i have decided that if i cant find a 07 cobalt to take everything out of then i probably wont do it.
Old Sep 26, 2012 | 12:04 PM
07-08 will work. mechanically, 2005-2008 are identical. just the wiring and ECM/TCM (which changed to a single PCM unit) changed after 2007. Just make sure your parts car isn't an SS/SC or SS/TC. Go with an SS/NA or LS/LT/LTZ for your parts
Old Sep 26, 2012 | 01:21 PM
bluebalt07's Avatar
If all you are looking for is a manual, than you can find one just like you have with a manual trans. It'll be cheaper and so much easier than trying to do the swap. If you really can get almost 10 for your car, you could find a manual cobalt 2.2 for cheaper than that so you'd have a manual and actually have made some money instead of totally ripping your car apart and spending a fortune
Old Sep 26, 2012 | 01:36 PM
Fitz88's Avatar
if its an 07 lt, you wont get 10k
Old Sep 26, 2012 | 09:22 PM
BLKLS's Avatar
He forgot, a shifter, shifter cables, a clutch cable, clutch line, shift boot, maybe a center console (no idea if they are different) It's a lot of work but hey people do it to civics all the time. Go for it. Your best bet is gonna be to buy an 07 with rear damage. If you have both cars next to each other you'll have all you need.
Old Sep 26, 2012 | 10:39 PM
bluebalt07's Avatar
^no clutch cable but the rest, yes. Consoles might be the same. Also forgot that there is a couple clutch postion sensors that would need to be had and wired too.
Old Sep 29, 2012 | 02:11 AM
SlobatLT's Avatar
I beg to differ. My car is a lt2 with 40,372 miles and in excellent condition. now is it really worth 10? nah not really but with all the things in my sig were gonna go with it. two of my friends offered to buy it for 10 when i was seriously about to get the ss/tc i was previously talking about. see they know my car has been tooken care of and not rode hard and put up wet. you always take a chance when you buy a used car so it makes all the difference when they know ive always taken good care of it. but aside from all that 40,xxx miles for a 07 is pretty damn good.
anyways, know one has answered this question directly.
"If I take everything out of a 07 balt can I use the pcm from that car since they are the same year?"
or would I have to get it tuned?
Old Sep 29, 2012 | 09:46 AM
BLKLS's Avatar
Should be able to, don't know if it will have to be flashed from GM to your vin number tho.
Old Oct 1, 2012 | 12:16 AM
bhager429's Avatar
dude just drop the engine core support and unhook everything and unbolt struts and install manual in. alot easyer the install wiring harness and lines. about a 2 day job did my 05 with a 06 with 23*** miles cant tell anything other then when u buy engine parts and clutch
Posted from Cobaltss.net App for Android
Old Oct 1, 2012 | 12:36 AM
Fitz88's Avatar
i lost all respect when u used the word "tooken"
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
