Tsudo Header
Tsudo Header
Has anyone used a Tsudo header before? I found one last night and it seemed to look decent for a 4-2-1. I havent seen or heard anything about this before and I was wondering if it sounds good paired up with the Tsudo exhaust.
yes it is, some of the cavi engines were backwards to ours and so it had to go under the car
it will work but you will need a custome dp/ exhuast setup and the turn for the dp to go back may have to be so tight that it causes flow problems
z28addiction
Sep 28, 2015 12:03 AM
