Turbo 2.2 05Cobalt
Originally Posted by cobaltLStrubo
the reason it is more expensive for higher stages is becuase you get the internals to keep that turbo. you are not going to throw on a t4 turbo with no work. the stage is there to put your car at the MINIMUM to handle the boost. meaning. You will probably have to buy more to handle what the stage seels for the amount of boost you want
If you want to look like a dork, go ask someone with a modified STI or GTI what "Stage" he has..
just so you know. the turbo that hahn racecraft makes for the 2005 cavalier can be altered to fit the cobalt 2.2 eco tec. for close to 400 dollars. I did it with mine and all they did was shorten some pipes and bend them around. it wasnt that hard for them to do and I have had it for about 5 months and it works great. 120 hp gain with the stage 3. The stage 2 is a safe bet. it isn't mush to upgrade to the 3. They are working on the stage 4 and 5 for the cobalt itself. just thought I would let you know. www.hahnracecraft.com
I'm not doubting that you put a turbo on your car, but you did not put a kit designed for the Cobalt on.
Originally Posted by Halfcent
Really? That's funny, because I was just saw Bill 2 weeks ago at his shop and we talked about how he won't put a kit on the Cobalt due to not having the ECU part figured out yet. But you have had one 5 months, eh?
Well, I wasn't trying to be a smart ass, but after re-reading my post I see that it does sound that way. So I apologize.
To continue, what are you using as engine management? That seems to be the problem at the moment.
Just to solve the whole matter of "no one sells a turbo kit for the 2.2 cobalt" heres a site that does.... and yesss it for the 2.2 cobalt
http://www.maximumboost.net/index.ph...=21_44_148_272
dont take this to offense, but you need to do ALOT of reading before u even think about T/C a 2.2 you seem to know nothing about cobalts or cars in general. A turbo isnt like a sticker. U cant just slap it on and expect it to stay there and work as intended. There is maintainance and other issues that go along with it. IF you want a tb car RIGHT NOW then buy a srt 4 because you dont have the knowledge at this time to successfully put together a reliable turbo on your own.
again dont take this as an insult im just calling it how i see it
i take it none of you own a turbo car. stages usually indcate what amunt of psi you can safetly run through your compressor. stage one kits usually have a psi of 6-7. stage two kits have around 8-10. stage 5 kits exeed 25 PSI. The price ranges go up to compensate for better products to maintain your system. An intercooler to lower intake air temps, a turbo timer to keep oil from harding in the system and heads, wastegate and blow off valves to release excess pressure. engine management to increase air fuel mixture and timing. Usually a stage 1 kit can be added to a car without modifying anything. Not my recomdation though. Stage 2 kits usaully just add an intercooler and maybe a boost controller. from experince owning a turbo car, make sure you have a turbo timer.
Like said before, stages mean nothing as far as "kits" go. If they did, what stage would people be if they did a custom setup? (retoricle question).
And just to add, you said:
Just so people don't get confussed, wastegates and blow off valves work on the opposite sides of the motor. A wastegate is there to bleed exhaust flow away from the turbine to limit the amount of boost someone is or should be running. It opens when it's at it's limit and remains closed when it isn't.
Blow off valves work to releave pressure on the intake side. It releaves pressure everytime you release your foot off the gas pedal. The more pressure you give, the more pressure is releaved and the louder it will be (with atmospheric blow off valves).
